    my mirror freezes!
    98 Posts 5 Posters 58.3k Views 4 Watching
      mr_cd
      @Bugsounet MMM-Logging was also installed after the Mirror freezes. Maybe i can disable the Third Party modules and see if it still freezes?!
        A Former User
        of course try ;)
          A Former User
          humm, i think to other things…
          Do you use Raspotify program ?
            mr_cd
            No i dont - but i used MMM-Spotify but i disabled it because of this freezing problem. But it still freezes…
              mr_cd
              But there is one suspect thing.
              When the Mirror freeze, im not able to connect with VNC. But how affect the MM Software the VNC Connection? Maybe there is a Problem with WLAN Connection…?!
              ? S 2 Replies Last reply
                A Former User
                so continue to disable modules one by one…
                and default too … to discover the responsible module
                  A Former User @mr_cd
                  @mr_cd : yes but it will not freeze… just display warning
                    sdetweil @mr_cd
                    @mr_cd how much swap space do you have? and is used?
                    free -m will show info
                      mr_cd
                      if the mirror is running.
                      But lets define the word freeze : I mean the clock is still working - but the modules like wheather or calender ar not updating…
                        sdetweil @mr_cd
                        @mr_cd but u also said vnc doesn’t work.
                          sdetweil @mr_cd
                          @mr_cd clock is working from internal timer… others require internet connection to update
                            mr_cd
                            @sdetweil correct. But when i plug in the USB mouse into rasperry iam able to work. After rebooting the system it works every time without problem
                              sdetweil @mr_cd
                              @mr_cd so, not really a ‘freeze’… MM stops working… system is ok, except for networking, recovers on reboot…
                              sounds like network went to sleep. there is a powersave setting on wifi…
                                mr_cd
                                seems to be ok…
                                  sdetweil @mr_cd
                                  @mr_cd well, that ain’t it! thx
                                    mr_cd
                                    @sdetweil but i could be because im working with it. i need to check during the next “freeze” when i connect directly with the mouse if the power save mode is still off.
                                      A Former User
                                      yes because… we lack ideas. this will allow us to reflect
                                        sdetweil @mr_cd
                                        @mr_cd it shouldn’t change the config by itself…
                                        but thank you, it forced me to check one system I have that seemed/s to have netowkr connection troubles…
                                        PM was on… now off
                                          mr_cd
                                          @Bugsounet @sdetweil Okay thats good :) luckily we could fix one Problem !
                                          Lets see i will find a solution - if you having new ideas pleas inform me , if i find the problem i will keep you up to date!
                                          • 5 / 5
