Solved MMM-SoccerLiveScore pleas help
hello, I installed this module and it makes my MM crash, after having been
First of all I want to apologize because I use a translator, I live in France and it’s easier for me
helped on the forum (thanks to @detweiler) it would seem that there is an error in the module, is it possible that the author fixes this error , thank you in advance for the work done by the authors who provide these little wonders
the author of the module, a great respect to him:
LukeSkywalker92 -
I forgot! the detected error is as follows:
@Manu85 from the log
looks like MMM-SoccerLiveScore/ had a fatal error when no data was presented
[ERROR] [31m[1m2020-04-07T09:00:27 SyntaxError: Unexpected token u in JSON at position 0[22m[39m
0|MagicMir | [31m[1m at JSON.parse ()[22m[39m
0|MagicMir | [31m[1m at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:192:29)
and that error killed MM
0|MagicMir | [2020-04-07 09:00:27.567] [LOG] 2020-04-07T09:00:27 Whoops! There was an uncaught exception… (/home/pi/MagicMirror/js/app.js:39 process.)
0|MagicMir | [2020-04-07 09:00:27.592] [LOG] 2020-04-07T09:00:27 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? (/home/pi/MagicMirror/js/app.js:41 process.) -
@Manu85 i posted this in your other topic
the module author posted in 2018 that he no longer had time to maintain this module…
I looked at the code and all the data operations do not check for errors. so there is quite a bit of work to fix the module
@sdetweil ah sh*t, it was really really good this module
@Manu85 yes …That was a nice Module
https://github.com/lavolp3/MMM-soccer
I think this is also a good module.
@Stoffbeuteluwe thank you i will try it, thank you again
@Manu85 i think i have fixed the module so it doesn’t crash…
do this
cd ~/MagicMirror/modules git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive cd MMM-SoccerLiveScore cp ../NewSoccerLive/*.js .
then restart your mirror app…
pm2 restart 0
if using pm2this will replace the two files with my version… no other changes required…
if there is a request error, we wait 5 minutes and try again -
@sdetweil I just did the manipulations that you advised and the module restarted, I keep you informed of the stability, but well done for your responsiveness
@sdetweil after a few hours the module becomes unstable.
