    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 26.9k Views 5 Watching
      Manu85
      hello, I installed this module and it makes my MM crash, after having been
      First of all I want to apologize because I use a translator, I live in France and it’s easier for me
      helped on the forum (thanks to @detweiler) it would seem that there is an error in the module, is it possible that the author fixes this error , thank you in advance for the work done by the authors who provide these little wonders
      the author of the module, a great respect to him:
      LukeSkywalker92
        Manu85
        I forgot! the detected error is as follows:
        @Manu85 from the log
        looks like MMM-SoccerLiveScore/ had a fatal error when no data was presented
        [ERROR] 2020-04-07T09:00:27 SyntaxError: Unexpected token u in JSON at position 0
        0|MagicMir |  at JSON.parse ()
        0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:192:29)
        and that error killed MM
        0|MagicMir | [2020-04-07 09:00:27.567] [LOG] 2020-04-07T09:00:27 Whoops! There was an uncaught exception… (/home/pi/MagicMirror/js/app.js:39 process.)
        0|MagicMir | [2020-04-07 09:00:27.592] [LOG] 2020-04-07T09:00:27 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? (/home/pi/MagicMirror/js/app.js:41 process.)
          sdetweil @Manu85
          @Manu85 i posted this in your other topic
          the module author posted in 2018 that he no longer had time to maintain this module…
          I looked at the code and all the data operations do not check for errors. so there is quite a bit of work to fix the module
            Manu85
            @sdetweil ah sh*t, it was really really good this module
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @Manu85
              @Manu85 yes …That was a nice Module
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
                https://github.com/lavolp3/MMM-soccer
                I think this is also a good module.
                  Manu85
                  @Stoffbeuteluwe thank you i will try it, thank you again
                    sdetweil @Manu85
                    @Manu85 i think i have fixed the module so it doesn’t crash…
                    do this
                    cd ~/MagicMirror/modules
                    git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive
                    cd MMM-SoccerLiveScore
                    cp ../NewSoccerLive/*.js .
                    then restart your mirror app…
                    pm2 restart 0
                    if using pm2
                    this will replace the two files with my version… no other changes required…
                    if there is a request error, we wait 5 minutes and try again
                      Manu85
                      @sdetweil I just did the manipulations that you advised and the module restarted, I keep you informed of the stability, but well done for your responsiveness
                        Manu85
                        @sdetweil after a few hours the module becomes unstable.
                          sdetweil @Manu85
                          @Manu85 ok, add
                          debug:true,
                          To the module config section
                          And restart mirror
                            Manu85
                            @sdetweil like this?
                            disabled:false,
                            module: ‘MMM-SoccerLiveScore’,
                            position: ‘top_right’,
                            header: ‘Scores en direct’,
                            leagues: [34, 1, 8],
                            showNames: true,
                            showLogos: true,
                            debug:true,
                            displayTime: 60 * 1000,
                            showTables: true
                              sdetweil @Manu85
                              @Manu85 yes
                                Manu85
                                @sdetweil hello, this morning my mirror is frozen and the soccer module is not present, I send you the somefile file by email, thank you
                                  sdetweil @Manu85
                                  @Manu85 MMM-SoccerLive is still running, and is still running the old node_helper.js
                                  0|MagicMir | [2020-04-08 07:23:29.709] [ERROR] 2020-04-08T07:23:29 SyntaxError: Unexpected token u in JSON at position 0
                                  0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                                    Manu85
                                    @sdetweil What can I do?
                                      sdetweil @Manu85
                                      @Manu85 the module is still active in the config.js
                                        Manu85
                                        this is how it is in the config.js
                                        disabled:false,
                                        showNames: true,
                                        showLogos: true,
                                        debug:true,
                                        showTables: true
                                          sdetweil @Manu85
                                          @Manu85 said in MMM-SoccerLiveScore pleas help:
                                          disabled:false,
                                          needs to be
                                          disabled:true,
                                            Manu85
                                            ok I did “disabled: true,” and I restarted the MM, the module no longer appears
