    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 27.7k Views 5 Watching
      sdetweil @Manu85
      @Manu85 ok, add
      debug:true,
      To the module config section
      And restart mirror
        Manu85
        @sdetweil like this?
        disabled:false,
        module: ‘MMM-SoccerLiveScore’,
        position: ‘top_right’,
        header: ‘Scores en direct’,
        leagues: [34, 1, 8],
        showNames: true,
        showLogos: true,
        debug:true,
        displayTime: 60 * 1000,
        showTables: true
          sdetweil @Manu85
          @Manu85 yes
            Manu85
            @sdetweil hello, this morning my mirror is frozen and the soccer module is not present, I send you the somefile file by email, thank you
              sdetweil @Manu85
              @Manu85 MMM-SoccerLive is still running, and is still running the old node_helper.js
              0|MagicMir | [2020-04-08 07:23:29.709] [ERROR] 2020-04-08T07:23:29 SyntaxError: Unexpected token u in JSON at position 0
              0|MagicMir |  at JSON.parse ()
              0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                Manu85
                @sdetweil What can I do?
                  sdetweil @Manu85
                  @Manu85 the module is still active in the config.js
                    Manu85
                    this is how it is in the config.js
                    disabled:false,
                    showNames: true,
                    showLogos: true,
                    debug:true,
                    showTables: true
                      sdetweil @Manu85
                      @Manu85 said in MMM-SoccerLiveScore pleas help:
                      disabled:false,
                      needs to be
                      disabled:true,
                        Manu85
                        ok I did “disabled: true,” and I restarted the MM, the module no longer appears
                          Manu85
                          disabled:true,
                          showNames: true,
                          showLogos: true,
                          debug:true,
                          showTables: true
                            sdetweil @Manu85
                            @Manu85 ok… looks good…
                            however, the node_helper in the module folder is also the old one… not the new that you were supposed to have copied…
                              Manu85
                              @sdetweil yet I followed your instructions, but I may have made a mistake! what should I do?
                                sdetweil @Manu85
                                @Manu85
                                cd ~/MagicMirror/modules
                                mv MMM-SoccerLiveScore MMM-SoccerLiveScore.old
                                mv NewSoccerLive MMM-SoccerLiveScore
                                cd MMM-SoccerLiveScore
                                npm install
                                then u can change disabled: back to false
                                  Manu85
                                  I made all the lines and went to false, the MM started but soccer does not appear on the screen
                                    sdetweil @Manu85
                                    @Manu85 output of
                                    pm2 logs --lines=100
                                    please
                                      Manu85
                                      @sdetweil in your mailbox
                                        sdetweil @Manu85
                                        @Manu85 makes no sense…
                                        can u edit ~/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                                        and show me the top few lines, should look like this
                                        /* Magic Mirror
                                         * Module: MyCovid19
                                         * Node_helper written by sdetweil
                                        const NodeHelper = require('node_helper');
                                        const request = require('request');
                                        const path = require('path')
                                        var moment = require('moment');
                                        //const cvt=require("xlsx-to-json")
                                        const cvt=require('csvtojson')
                                        var fs=require('fs')
                                          Manu85
                                          @sdetweil I have a file “/home/pi/MagicMirror/modules/MMM-SoccerLiveScore.old” and in this file I have another file “MMM-SoccerLiveScore” is this file “node_helper.js” you want?
                                            sdetweil @Manu85
                                            @Manu85 i have no idea what you did… there should be two folders in ~/MagicMirror/modules (related to this problem)
                                            MMM-SoccerLiveScore.old the original module
                                            MMM-SoccerLiveScore my updated module, rename from NewSoccerLive
