    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 26.9k Views 5 Watching
      sdetweil @Manu85
      @Manu85 i think i have fixed the module so it doesn’t crash…
      do this
      cd ~/MagicMirror/modules
      git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive
      cd MMM-SoccerLiveScore
      cp ../NewSoccerLive/*.js .
      then restart your mirror app…
      pm2 restart 0
      if using pm2
      this will replace the two files with my version… no other changes required…
      if there is a request error, we wait 5 minutes and try again
        Manu85
        @sdetweil I just did the manipulations that you advised and the module restarted, I keep you informed of the stability, but well done for your responsiveness
          Manu85
          @sdetweil after a few hours the module becomes unstable.
            sdetweil @Manu85
            @Manu85 ok, add
            debug:true,
            To the module config section
            And restart mirror
              Manu85
              @sdetweil like this?
              disabled:false,
              module: ‘MMM-SoccerLiveScore’,
              position: ‘top_right’,
              header: ‘Scores en direct’,
              leagues: [34, 1, 8],
              showNames: true,
              showLogos: true,
              debug:true,
              displayTime: 60 * 1000,
              showTables: true
                sdetweil @Manu85
                @Manu85 yes
                  Manu85
                  @sdetweil hello, this morning my mirror is frozen and the soccer module is not present, I send you the somefile file by email, thank you
                    sdetweil @Manu85
                    @Manu85 MMM-SoccerLive is still running, and is still running the old node_helper.js
                    0|MagicMir | [2020-04-08 07:23:29.709] [ERROR] 2020-04-08T07:23:29 SyntaxError: Unexpected token u in JSON at position 0
                    0|MagicMir |  at JSON.parse ()
                    0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                      Manu85
                      @sdetweil What can I do?
                        sdetweil @Manu85
                        @Manu85 the module is still active in the config.js
                          Manu85
                          this is how it is in the config.js
                          disabled:false,
                          showNames: true,
                          showLogos: true,
                          debug:true,
                          showTables: true
                            sdetweil @Manu85
                            @Manu85 said in MMM-SoccerLiveScore pleas help:
                            disabled:false,
                            needs to be
                            disabled:true,
                              Manu85
                              ok I did “disabled: true,” and I restarted the MM, the module no longer appears
                                Manu85
                                disabled:true,
                                showNames: true,
                                showLogos: true,
                                debug:true,
                                showTables: true
                                  sdetweil @Manu85
                                  @Manu85 ok… looks good…
                                  however, the node_helper in the module folder is also the old one… not the new that you were supposed to have copied…
                                    Manu85
                                    @sdetweil yet I followed your instructions, but I may have made a mistake! what should I do?
                                      sdetweil @Manu85
                                      @Manu85
                                      mv MMM-SoccerLiveScore MMM-SoccerLiveScore.old
                                      mv NewSoccerLive MMM-SoccerLiveScore
                                      npm install
                                      then u can change disabled: back to false
                                        Manu85
                                        I made all the lines and went to false, the MM started but soccer does not appear on the screen
                                          sdetweil @Manu85
                                          @Manu85 output of
                                          pm2 logs --lines=100
                                          please
                                            Manu85
                                            @sdetweil in your mailbox
