    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 27.7k Views 5 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
      https://github.com/lavolp3/MMM-soccer
      I think this is also a good module.
        Manu85
        @Stoffbeuteluwe thank you i will try it, thank you again
          sdetweil @Manu85
          @Manu85 i think i have fixed the module so it doesn’t crash…
          do this
          cd ~/MagicMirror/modules
          git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive
          cd MMM-SoccerLiveScore
          cp ../NewSoccerLive/*.js .
          then restart your mirror app…
          pm2 restart 0
          if using pm2
          this will replace the two files with my version… no other changes required…
          if there is a request error, we wait 5 minutes and try again
            Manu85
            @sdetweil I just did the manipulations that you advised and the module restarted, I keep you informed of the stability, but well done for your responsiveness
              Manu85
              @sdetweil after a few hours the module becomes unstable.
                sdetweil @Manu85
                @Manu85 ok, add
                debug:true,
                To the module config section
                And restart mirror
                  Manu85
                  @sdetweil like this?
                  disabled:false,
                  module: ‘MMM-SoccerLiveScore’,
                  position: ‘top_right’,
                  header: ‘Scores en direct’,
                  leagues: [34, 1, 8],
                  showNames: true,
                  showLogos: true,
                  debug:true,
                  displayTime: 60 * 1000,
                  showTables: true
                    sdetweil @Manu85
                    @Manu85 yes
                      Manu85
                      @sdetweil hello, this morning my mirror is frozen and the soccer module is not present, I send you the somefile file by email, thank you
                        sdetweil @Manu85
                        @Manu85 MMM-SoccerLive is still running, and is still running the old node_helper.js
                        0|MagicMir | [2020-04-08 07:23:29.709] [ERROR] 2020-04-08T07:23:29 SyntaxError: Unexpected token u in JSON at position 0
                        0|MagicMir |  at JSON.parse ()
                        0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                          Manu85
                          @sdetweil What can I do?
                            sdetweil @Manu85
                            @Manu85 the module is still active in the config.js
                              Manu85
                              this is how it is in the config.js
                              disabled:false,
                              showNames: true,
                              showLogos: true,
                              debug:true,
                              showTables: true
                                sdetweil @Manu85
                                @Manu85 said in MMM-SoccerLiveScore pleas help:
                                disabled:false,
                                needs to be
                                disabled:true,
                                  Manu85
                                  ok I did “disabled: true,” and I restarted the MM, the module no longer appears
                                    Manu85
                                    disabled:true,
                                    showNames: true,
                                    showLogos: true,
                                    debug:true,
                                    showTables: true
                                      sdetweil @Manu85
                                      @Manu85 ok… looks good…
                                      however, the node_helper in the module folder is also the old one… not the new that you were supposed to have copied…
                                        Manu85
                                        @sdetweil yet I followed your instructions, but I may have made a mistake! what should I do?
                                          sdetweil @Manu85
                                          @Manu85
                                          mv MMM-SoccerLiveScore MMM-SoccerLiveScore.old
                                          mv NewSoccerLive MMM-SoccerLiveScore
                                          npm install
                                          then u can change disabled: back to false
                                            Manu85
                                            I made all the lines and went to false, the MM started but soccer does not appear on the screen
