    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 27.7k Views 5 Watching
      Manu85
      I forgot! the detected error is as follows:
      @Manu85 from the log
      looks like MMM-SoccerLiveScore/ had a fatal error when no data was presented
      [ERROR] 2020-04-07T09:00:27 SyntaxError: Unexpected token u in JSON at position 0
      0|MagicMir |  at JSON.parse ()
      0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:192:29)
      and that error killed MM
      0|MagicMir | [2020-04-07 09:00:27.567] [LOG] 2020-04-07T09:00:27 Whoops! There was an uncaught exception… (/home/pi/MagicMirror/js/app.js:39 process.)
      0|MagicMir | [2020-04-07 09:00:27.592] [LOG] 2020-04-07T09:00:27 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? (/home/pi/MagicMirror/js/app.js:41 process.)
        sdetweil @Manu85
        @Manu85 i posted this in your other topic
        the module author posted in 2018 that he no longer had time to maintain this module…
        I looked at the code and all the data operations do not check for errors. so there is quite a bit of work to fix the module
          Manu85
          @sdetweil ah sh*t, it was really really good this module
          StoffbeuteluweS 1 Reply Last reply
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor @Manu85
            @Manu85 yes …That was a nice Module
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
              https://github.com/lavolp3/MMM-soccer
              I think this is also a good module.
                Manu85
                @Stoffbeuteluwe thank you i will try it, thank you again
                  sdetweil @Manu85
                  @Manu85 i think i have fixed the module so it doesn’t crash…
                  do this
                  cd ~/MagicMirror/modules
                  git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive
                  cd MMM-SoccerLiveScore
                  cp ../NewSoccerLive/*.js .
                  then restart your mirror app…
                  pm2 restart 0
                  if using pm2
                  this will replace the two files with my version… no other changes required…
                  if there is a request error, we wait 5 minutes and try again
                    Manu85
                    @sdetweil I just did the manipulations that you advised and the module restarted, I keep you informed of the stability, but well done for your responsiveness
                      Manu85
                      @sdetweil after a few hours the module becomes unstable.
                        sdetweil @Manu85
                        @Manu85 ok, add
                        debug:true,
                        To the module config section
                        And restart mirror
                          Manu85
                          @sdetweil like this?
                          disabled:false,
                          module: ‘MMM-SoccerLiveScore’,
                          position: ‘top_right’,
                          header: ‘Scores en direct’,
                          leagues: [34, 1, 8],
                          showNames: true,
                          showLogos: true,
                          debug:true,
                          displayTime: 60 * 1000,
                          showTables: true
                            sdetweil @Manu85
                            @Manu85 yes
                              Manu85
                              @sdetweil hello, this morning my mirror is frozen and the soccer module is not present, I send you the somefile file by email, thank you
                                sdetweil @Manu85
                                @Manu85 MMM-SoccerLive is still running, and is still running the old node_helper.js
                                0|MagicMir | [2020-04-08 07:23:29.709] [ERROR] 2020-04-08T07:23:29 SyntaxError: Unexpected token u in JSON at position 0
                                0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                                  Manu85
                                  @sdetweil What can I do?
                                    sdetweil @Manu85
                                    @Manu85 the module is still active in the config.js
                                      Manu85
                                      this is how it is in the config.js
                                      disabled:false,
                                      showNames: true,
                                      showLogos: true,
                                      debug:true,
                                      showTables: true
                                        sdetweil @Manu85
                                        @Manu85 said in MMM-SoccerLiveScore pleas help:
                                        disabled:false,
                                        needs to be
                                        disabled:true,
                                          Manu85
                                          ok I did “disabled: true,” and I restarted the MM, the module no longer appears
                                            Manu85
                                            disabled:true,
                                            showNames: true,
                                            showLogos: true,
                                            debug:true,
                                            showTables: true
