    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 27.7k Views 5 Watching
      Manu85
      @sdetweil like this?
      disabled:false,
      module: ‘MMM-SoccerLiveScore’,
      position: ‘top_right’,
      header: ‘Scores en direct’,
      leagues: [34, 1, 8],
      showNames: true,
      showLogos: true,
      debug:true,
      displayTime: 60 * 1000,
      showTables: true
        sdetweil @Manu85
        @Manu85 yes
          Manu85
          @sdetweil hello, this morning my mirror is frozen and the soccer module is not present, I send you the somefile file by email, thank you
            sdetweil @Manu85
            @Manu85 MMM-SoccerLive is still running, and is still running the old node_helper.js
            0|MagicMir | [2020-04-08 07:23:29.709] [ERROR] 2020-04-08T07:23:29 SyntaxError: Unexpected token u in JSON at position 0
            0|MagicMir |  at JSON.parse ()
            0|MagicMir |  at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
              Manu85
              @sdetweil What can I do?
                sdetweil @Manu85
                @Manu85 the module is still active in the config.js
                  Manu85
                  this is how it is in the config.js
                  disabled:false,
                  showNames: true,
                  showLogos: true,
                  debug:true,
                  showTables: true
                    sdetweil @Manu85
                    @Manu85 said in MMM-SoccerLiveScore pleas help:
                    disabled:false,
                    needs to be
                    disabled:true,
                      Manu85
                      ok I did “disabled: true,” and I restarted the MM, the module no longer appears
                        Manu85
                        disabled:true,
                        showNames: true,
                        showLogos: true,
                        debug:true,
                        showTables: true
                          sdetweil @Manu85
                          @Manu85 ok… looks good…
                          however, the node_helper in the module folder is also the old one… not the new that you were supposed to have copied…
                            Manu85
                            @sdetweil yet I followed your instructions, but I may have made a mistake! what should I do?
                              sdetweil @Manu85
                              @Manu85
                              cd ~/MagicMirror/modules
                              mv MMM-SoccerLiveScore MMM-SoccerLiveScore.old
                              mv NewSoccerLive MMM-SoccerLiveScore
                              cd MMM-SoccerLiveScore
                              npm install
                              then u can change disabled: back to false
                                Manu85
                                I made all the lines and went to false, the MM started but soccer does not appear on the screen
                                  sdetweil @Manu85
                                  @Manu85 output of
                                  pm2 logs --lines=100
                                  please
                                    Manu85
                                    @sdetweil in your mailbox
                                      sdetweil @Manu85
                                      @Manu85 makes no sense…
                                      can u edit ~/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                                      and show me the top few lines, should look like this
                                      /* Magic Mirror
                                       * Module: MyCovid19
                                       * Node_helper written by sdetweil
                                      const NodeHelper = require('node_helper');
                                      const request = require('request');
                                      const path = require('path')
                                      var moment = require('moment');
                                      //const cvt=require("xlsx-to-json")
                                      const cvt=require('csvtojson')
                                      var fs=require('fs')
                                        Manu85
                                        @sdetweil I have a file “/home/pi/MagicMirror/modules/MMM-SoccerLiveScore.old” and in this file I have another file “MMM-SoccerLiveScore” is this file “node_helper.js” you want?
                                          sdetweil @Manu85
                                          @Manu85 i have no idea what you did… there should be two folders in ~/MagicMirror/modules (related to this problem)
                                          MMM-SoccerLiveScore.old the original module
                                          MMM-SoccerLiveScore my updated module, rename from NewSoccerLive
                                            Manu85
                                            @sdetweil I just emailed you the screenshot of what I have, thanks again for your help
                                            • 2 / 3
