    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 26.9k Views 5 Watching
      sdetweil @Manu85
      @Manu85 the module is still active in the config.js
        Manu85
        this is how it is in the config.js
        disabled:false,
        module: ‘MMM-SoccerLiveScore’,
        position: ‘top_right’,
        header: ‘Scores en direct’,
        leagues: [34, 1, 8],
        showNames: true,
        showLogos: true,
        debug:true,
        displayTime: 60 * 1000,
        showTables: true
          sdetweil @Manu85
          @Manu85 said in MMM-SoccerLiveScore pleas help:
          disabled:false,
          needs to be
          disabled:true,
            Manu85
            ok I did “disabled: true,” and I restarted the MM, the module no longer appears
              Manu85
              disabled:true,
              showNames: true,
              showLogos: true,
              debug:true,
              showTables: true
                sdetweil @Manu85
                @Manu85 ok… looks good…
                however, the node_helper in the module folder is also the old one… not the new that you were supposed to have copied…
                  Manu85
                  @sdetweil yet I followed your instructions, but I may have made a mistake! what should I do?
                    sdetweil @Manu85
                    @Manu85
                    cd ~/MagicMirror/modules
                    mv MMM-SoccerLiveScore MMM-SoccerLiveScore.old
                    mv NewSoccerLive MMM-SoccerLiveScore
                    cd MMM-SoccerLiveScore
                    npm install
                    then u can change disabled: back to false
                      Manu85
                      I made all the lines and went to false, the MM started but soccer does not appear on the screen
                        sdetweil @Manu85
                        @Manu85 output of
                        pm2 logs --lines=100
                        please
                          Manu85
                          @sdetweil in your mailbox
                            sdetweil @Manu85
                            @Manu85 makes no sense…
                            can u edit ~/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                            and show me the top few lines, should look like this
                            /* Magic Mirror
                             * Module: MyCovid19
                             * Node_helper written by sdetweil
                            const NodeHelper = require('node_helper');
                            const request = require('request');
                            const path = require('path')
                            var moment = require('moment');
                            //const cvt=require("xlsx-to-json")
                            const cvt=require('csvtojson')
                            var fs=require('fs')
                              Manu85
                              @sdetweil I have a file “/home/pi/MagicMirror/modules/MMM-SoccerLiveScore.old” and in this file I have another file “MMM-SoccerLiveScore” is this file “node_helper.js” you want?
                                sdetweil @Manu85
                                @Manu85 i have no idea what you did… there should be two folders in ~/MagicMirror/modules (related to this problem)
                                MMM-SoccerLiveScore.old the original module
                                MMM-SoccerLiveScore my updated module, rename from NewSoccerLive
                                  Manu85
                                  @sdetweil I just emailed you the screenshot of what I have, thanks again for your help
                                    sdetweil @Manu85
                                    @Manu85 do
                                    cd ~/MagicMirror/modules/MMM-SoccerLiveScore.old
                                    mv MMM-SoccerLiveScore ..
                                    restart mirror
                                      Manu85
                                      I’m sorry, after passing these lines the screen remains black
                                        sdetweil @Manu85
                                        @Manu85 show me outout
                                          Manu85
                                          @sdetweil I just resumed our entire conversation and I just redid "cd ~ / MagicMirror / modules
                                          git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive
                                          cp …/NewSoccerLive/*.js. "
                                          I do not know if I did well, but I think I have abused your kindness enough, I send you the somefile on your email, thank you
                                            Manu85
                                            @sdetweil I sent you the email from somefile
                                            • 2 / 3
