    Samba - Save failing when Direct from PC to Pi
    8 Posts 3 Posters 1.4k Views 3 Watching
    • N Offline
      Nero
      Hi, first of all hello and I look forward to getting to know and understand more of MagicMirror over time. I am very new to all this and a total noob, I have managed to set up MM and add some modules but I am trying to set up Samba to remote access the files so i am able to update and add modules from my PC to MM. I have managed to set up a shortcut on Windows to remote access and I am able to see all the files on my Pi, thing is when I click a file to edit when saving I get told to try again in Admin mode and then that still fails and I get a notification Save Failed - Please check if this is file is opened in another program? I have no idea as I have tried shutting everything down and all kind of options but to no avail, any ideas please? PS sorry for the wall of text.
      Thiis is the code I have added on the bottom of Samba config:
      [share]
      Comment = Pi shared folder
      Path = /
      Browseable = yes
      Writeable = Yes
      only guest = no
      create mask = 0777
      directory mask = 0777
      Public = yes
      Guest ok = yes
        sdetweil @Nero
        @Nero easier, use the bitvise ssh client, then u can drag/drop, double click to edit, and have an ssh window open for commands too… free… easy
        N 1 Reply Last reply Reply Quote 2
        • N Offline
          Nero @sdetweil
          @sdetweil thanks for a quick response, I can try this tomorrow after work. How easy is it to set up to access the Files on my Pi? Bear in mind I’m pretty amateur still. Cheers
            sdetweil @Nero
            @Nero do you know how to use the windows explorer for file access…??
            u need to know the ip, and userid and password to ssh logon to the pi…
            thats it…
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              Nero @sdetweil
              @sdetweil Thank you very much, this works exactly how I wanted it too and so much easier. Cheers
              • lavolp3L Offline
                lavolp3 Module Developer
                Another good solution (for me) is WinSCP.
                You can open js files e.g. in notepad++ from winSCP.
                Drag+drop works as well.
                And ssh terminal supported as well.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  sdetweil @lavolp3
                  @lavolp3 yes, but bitvise opens BOTH types of connections at the same time.
                  I used WinSCP before, but always wanted an SSH command session open too…
                  I have 5 MM system connections open at once
                  • lavolp3L Offline
                    @sdetweil Thanks for the info I’ll have a look into it!
                    (This was the answer I haven’t been notified of :-) )
