thx, but dont have the line :/
this is in the email.js file :
defaults : { user: 'a@b.com', password: 'xxx', host: 'jjj.kkk.com', port: 993, tls: true, authTimeout: 10000, numberOfEmails: 5, fade: true }, payload: [], start : function(){ console.log("Email module started!"); this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded}); this.loaded = false; }, socketNotificationReceived: function(notification, payload){ if (notification === 'EMAIL_RESPONSE'){ if(payload){ this.loaded = true; var that = this; console.log("NEW PAYLOAD: ", payload); payload.forEach(function(m){ if(that.payload.indexOf(m.id) == -1) that.payload.push(m); }); this.payload.sort(function(a,b) {return b.id - a.id; }); this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded}); this.updateDom(2000); } } }, // Define required scripts. getStyles: function() { return ["email.css", "font-awesome.css"]; }, getDom: function(){ var wrapper = document.createElement("table"); wrapper.className = "small"; var that =this; if(this.payload.length > 0) { var count = 0; this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) { var name = mailObj.sender[0].name.replace(/['"]+/g,""); var subject = mailObj.subject.replace(/[\['"\]]+/g,""); var emailWrapper = document.createElement("tr"); emailWrapper.className = "normal"; var senderWrapper = document.createElement("tr"); senderWrapper.className = "normal"; var nameWrapper = document.createElement("td"); nameWrapper.className = "bright"; nameWrapper.innerHTML = name; senderWrapper.appendChild(nameWrapper); var addressWrapper = document.createElement("td"); addressWrapper.className = "address xsmall thin dimmed"; addressWrapper.innerHTML = mailObj.sender[0].address; senderWrapper.appendChild(addressWrapper); emailWrapper.appendChild(senderWrapper); var subjectWrapper = document.createElement("tr"); subjectWrapper.className = "light"; subjectWrapper.innerHTML = subject; emailWrapper.appendChild(subjectWrapper); wrapper.appendChild(emailWrapper); // Create fade effect. if (that.config.fade) { var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25; var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint; if (count >= startingPoint) { var currentStep = count - startingPoint; emailWrapper.style.opacity = 1 - (1 / steps * currentStep); } } count++; }); } else{ wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING"); wrapper.className = "small dimmed"; return wrapper; } return wrapper; }
var name = mailObj.sender[0].name.replace(/['"]+/g,""); var subject = mailObj.subject.replace(/[\['"\]]+/g,""); <----- **Here this line** var subject = subject.substring(0,30); <----- **New Line**
perfekt it works !!
but I’d love that is hidden, the email address and the mail before each a symbol appears is that possible? -
hello, thank you to help me by the email module !!
but I have a question
you can insert a symbol in front of the email?so i have think tis symbol
Errors
Email notifier error: { Error: read ECONNRESET
at exports._errnoException (util.js:1026:11)
at TCP.onread (net.js:564:26)
code: ‘ECONNRESET’,
errno: ‘ECONNRESET’,
syscall: ‘read’,
source: ‘socket’ }
code: ‘ECONNRESET’,
syscall: ‘read’,
source: ‘socket’ }
code: ‘ECONNRESET’,
syscall: ‘read’,
source: ‘socket’ }
code: ‘ECONNRESET’,
syscall: ‘read’,
source: ‘socket’ }
code: ‘ECONNRESET’,
syscall: ‘read’,
source: ‘socket’ } -
Hello ronny3050, the module is great, but after a while the module stands still. On my Mobilphone there are messages about new emails but your email Module does nothing. After a restart from the raspberry pi, everything is ok again, but after a few hours the same… Could you help me ?
Yours Peter van Evert -
@Peter_van_Evert hes offline since two months, you probably have more success with open an issue on github
@strawberry-3.141 @Peter_van_Evert I apologize for not being able to get back to you sooner - been busy with grad school. :( I replied on the issue on github. Thanks! :)
can anyone think of a reason the email is not updating to show new emails? i’m very new to this stuff, the temperature module is updating the temperature so its still connected.
thanks
