Mirror is blank even after preparing a config.js file
6 Posts 2 Posters 3.9k Views 2 Watching
  • T Offline
    taztrk
    Hi. I’m kind of new to ubuntu based operating systems and completely new to magic mirror and javascript. I prepared a config file based on the sample and the module information. When checked to see what the webpage looked like, there was the screen saying that i hadnt prepared a config file or that it had errors. So i did as advised and used jslint.com to debug the code until there were no more warnings. Now when I open the server page all i get is a blank screen. I think it might have something to do with the “there are no functions” phrase in the function report section of the jslint site but I have no clue. Could someone point me in the right direction please? Thanks
    P 1 Reply Last reply May 16, 2016, 9:15 PM Reply Quote 0
      paviro Admin @taztrk
      @taztrk make sure to check your web inspector (use the node serveronly function and a browser of your choice - there should be a thread about that somewhere) for errors.
      – The Doctor
      T 1 Reply Last reply May 17, 2016, 7:10 AM Reply Quote 0
      • T Offline
        taztrk
        I tried to follow the HOw to Troubleshoot forum. I downloaded firebug and did node serveronly and this is the result:
        pi@raspberrypi:/var/www/html/MagicMirror $ node serveronly
        module.js:440
            throw err;
        Error: Cannot find module 'express'
            at Function.Module._resolveFilename (module.js:438:15)
            at Function.Module._load (module.js:386:25)
            at Module.require (module.js:466:17)
            at require (internal/module.js:20:19)
            at Object.<anonymous> (/var/www/html/MagicMirror/js/server.js:8:15)
            at Module._compile (module.js:541:32)
            at Object.Module._extensions..js (module.js:550:10)
            at Module.load (module.js:456:32)
            at tryModuleLoad (module.js:415:12)
            at Function.Module._load (module.js:407:3)
        module.js:440
            throw err;
        I opened MM on firefox and used firebug but i didn´t see anything that looked like an error.
        P 1 Reply Last reply May 17, 2016, 6:48 AM Reply Quote 0
          @taztrk so you did not do npm install?
          – The Doctor
          • T Offline
            taztrk @paviro
            @paviro it turns out i didn’t. I did it now and got errors like this. Sorry for the screenshot before hand
            P 1 Reply Last reply May 17, 2016, 7:27 AM Reply Quote 0
              @taztrk please use Markdown on code snippets so it is easier to read :)
              Looks like your OS or node version is not supported by Electron. Try using Raspbian especially if you do not have much experience.
              – The Doctor
