    Mirror is blank even after preparing a config.js file
    6 Posts 2 Posters 4.4k Views 2 Watching
    • T
      taztrk
      Hi. I’m kind of new to ubuntu based operating systems and completely new to magic mirror and javascript. I prepared a config file based on the sample and the module information. When checked to see what the webpage looked like, there was the screen saying that i hadnt prepared a config file or that it had errors. So i did as advised and used jslint.com to debug the code until there were no more warnings. Now when I open the server page all i get is a blank screen. I think it might have something to do with the “there are no functions” phrase in the function report section of the jslint site but I have no clue. Could someone point me in the right direction please? Thanks
      P 1 Reply Last reply
        paviro @taztrk
        @taztrk make sure to check your web inspector (use the node serveronly function and a browser of your choice - there should be a thread about that somewhere) for errors.
        – The Doctor
        T 1 Reply Last reply
        • T
          taztrk
          I tried to follow the HOw to Troubleshoot forum. I downloaded firebug and did node serveronly and this is the result:
          pi@raspberrypi:/var/www/html/MagicMirror $ node serveronly
          module.js:440
              throw err;
          Error: Cannot find module 'express'
              at Function.Module._resolveFilename (module.js:438:15)
              at Function.Module._load (module.js:386:25)
              at Module.require (module.js:466:17)
              at require (internal/module.js:20:19)
              at Object.<anonymous> (/var/www/html/MagicMirror/js/server.js:8:15)
              at Module._compile (module.js:541:32)
              at Object.Module._extensions..js (module.js:550:10)
              at Module.load (module.js:456:32)
              at tryModuleLoad (module.js:415:12)
              at Function.Module._load (module.js:407:3)
          module.js:440
              throw err;
          I opened MM on firefox and used firebug but i didn´t see anything that looked like an error.
            paviro @taztrk
            @taztrk so you did not do npm install?
            – The Doctor
            • T
              taztrk @paviro
              @paviro it turns out i didn’t. I did it now and got errors like this. Sorry for the screenshot before hand
                paviro @taztrk
                @taztrk please use Markdown on code snippets so it is easier to read :)
                Looks like your OS or node version is not supported by Electron. Try using Raspbian especially if you do not have much experience.
                – The Doctor
