    Update available 2997 commits behind
    4 Posts 2 Posters 944 Views 2 Watching
      Canguingo
      Hi there,
      I have a Magic Mirror that I was working with last year. I tried to recover this project but the Mirror gives me a warning on the top that says:
      MagicMirror update available
      Your actual installation is 2997 commits behind from the Master Branch.
      I tried to upgrade with git pull but nothing happened.
      I have noticed that there is a new version: https://forum.magicmirror.builders/topic/12460/v2-11-0
      Do I need to re-install the software again or is there a way to updated in a different way?
      (You’ll proably need to know the version of my MagicMirror, how do I find out which version do I have?)
      Many thanks in advance!
      Cheers, JD
        sdetweil @Canguingo
        @Canguingo run my upgrade script
        See https://github.com/sdetweil/MagicMirror_scripts
        Read the readme for the commands to issue
          Canguingo
          Thank you Sam. But this doesn’t solve the issue. At least if I follow the instructions from the Read.me.
          It says update available. but how to update it? isn’t there a line of code to run and update it every time this shows up?
            sdetweil @Canguingo
            @Canguingo to update from my scripts is a 2 step process, right?
            upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
            it should handle all the work… and give you a trial run of all that…
            only applying changes if u request them
            give it a try this works on Mac as well, cut/paste this line into the terminal window on your device
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            ------> no changes are made to the local repo or the working copy  < ---------
            if you WANT to actually apply the changes, cut/paste this line into the terminal window on your device
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            there is a log file (upgrade.log) in the MagicMirror/installers folder…
