    Weather module config
    19 Posts 2 Posters 7.0k Views 2 Watching
      mrlowndes
      Just to clarify, I’m talking about the ‘weather’ module, NOT the ‘current weather’ or 'weather forecast" modules. I have added it to my config.js file with some configurations, as outlined in the documentation for the ‘weather’ module, but it wont run. Question for module configs, do I use "true", or 'true', to encapsulate my values? Its seems to vary depending on what I’m reading. Here is my config.js script:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "currentweather",
      				locationID: "5392952", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "112847e0ff924d7f26338d5873e7be3d"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "xxxxxxxxxxxxxx"
      		module: "weather",
      			weatherProvider: "weathergov",
      			units: "metric",
      			roundTemp: "true",
      			degreeLabel: "true",
      			updateInterval" "3600000",
      			colored: "true",
      			showPrecipitationAmount: "true",
      			apiBase: "https://api.weather.gov/points/",
      			weatherEndpoint: "/forecast",
      			lat: "xxx.xxxxxx",
      			lon: "xxx.xxxxxx",
      			type: "forecast"
      and here are the errors I’m getting:
      [2020-04-28 11:31:59.700] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:65
      SyntaxError: Unexpected string
          at Module._compile (internal/modules/cjs/loader.js:722:23)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
          at App.start (/home/pi/MagicMirror/js/app.js:210:3)
          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7)
          at Module._compile (internal/modules/cjs/loader.js:786:30)
        sdetweil @mrlowndes
        @mrlowndes for numbers or true/false, no quotes, all else with quotes, doesn’t matter which kind as long as both ends are the same
        in a list it can be either for each entry, as long as both ends are the same
        updateInterval" “3600000”,
        should be name: value
        so
        updateInterval : “3600000”,
          mrlowndes
          @sdetweil thanks. That got rid of the errors, now when I npm start the weather module seems to be just loading indefinitely. Any ideas?
            sdetweil @mrlowndes
            @mrlowndes did u get an apiid? ‘loading’ means waiting for data … so, the component getting the data did not succeed
            npm start
            then look at the messages
            or possibly open the developers window (f12 or ctrl-shift-i) select the console tab, and scroll up looking for errors…
              @mrlowndes said in Weather module config:
              index):1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
              ok, don’t know for the slow network.
              but for this one
              do
              touch ~/MagicMirror/css/custom.css
                mrlowndes @sdetweil
                @sdetweil Thanks for the tip. The errors were at the bottom. This is what I found:
                Failed to load resource: the server responded with a status of 400 ()
                weathergov.js:55 Could not load data ...
                XMLHttpRequest
                weather.js:151 New weather information available.
                main.js:301 [Intervention] Slow network is detected. See https://www.chromestatus.com/feature/5636954674692096 for more details. Fallback font will be used while loading: http://localhost:8080/vendor/node_modules/weathericons/font/weathericons-regular-webfont.woff
                api.openweathermap.o…xxxxxxxxxxxxxxxx:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
                weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled
                  mrlowndes
                  @sdetweil do you know where I could get an appid for weathergov? The documentation for the module is very thin
                    no key required for that point… only works for US locations
                      mrlowndes @sdetweil
                      @sdetweil Do you have any suggestions as to what I should try next?
                        sdetweil @mrlowndes
                        @mrlowndes u can test that the api works from your location
                        put this in your browser
                        https://api.weather.gov/points/LAT,LON/forecast
                        replace the LAT,LON
                        by the values from the google maps (maps.google.com) of your location…
                        in the url, you will see two numbers xx.yyyyyy,-uu.zzzzzz
                        just cut/paste that whole set of numbers and paste over the LAT,LON (notice the comma comes with the numbers too)
                          mrlowndes
                          @sdetweil Thanks so much, the documentation doesn’t make that clear at all
                            sdetweil @mrlowndes
                            @mrlowndes no, this is just a test… making sure the api would work as called by the module
                              mrlowndes @sdetweil
                              @sdetweil yeah, no dice. This came up in my browser
                              "title": "Data Unavailable For Requested Point",
                                  "type": "https://api.weather.gov/problems/InvalidPoint",
                                  "status": 404,
                                  "detail": "Unable to provide data for requested point 34.5444,119.7913",
                                  "instance": "https://api.weather.gov/requests/8199fbe2-ac6c-4c7c-b109-ed162794f780"
                                sdetweil @mrlowndes
                                @mrlowndes as I said, only works for US locations
                                  mrlowndes
                                  @sdetweil yeah, it is a US location
                                    sdetweil @mrlowndes
                                    @mrlowndes how can +119 be US location , mine is minus 97 (west of london)
                                      mrlowndes
                                      @sdetweil I’m using the lat long listed here: https://forecast.weather.gov/MapClick.php?lat=34.54167&lon=-119.80917#.XqhoOJp7kWr
                                        sdetweil @mrlowndes
                                        @mrlowndes u forgot the - sign
                                        34.5444,119.7913",
                                          mrlowndes
                                          @sdetweil haha well that was dumb of me. I copied it from the web page where there isn’t a minus, but in the URL there obviously is. Thanks so much! got it working!
