    Weather module config
    19 Posts 2 Posters 7.1k Views 2 Watching
      no key required for that point… only works for US locations
        mrlowndes @sdetweil
        @sdetweil Do you have any suggestions as to what I should try next?
          sdetweil @mrlowndes
          @mrlowndes u can test that the api works from your location
          put this in your browser
          https://api.weather.gov/points/LAT,LON/forecast
          replace the LAT,LON
          by the values from the google maps (maps.google.com) of your location…
          in the url, you will see two numbers xx.yyyyyy,-uu.zzzzzz
          just cut/paste that whole set of numbers and paste over the LAT,LON (notice the comma comes with the numbers too)
            mrlowndes
            @sdetweil Thanks so much, the documentation doesn’t make that clear at all
              sdetweil @mrlowndes
              @mrlowndes no, this is just a test… making sure the api would work as called by the module
                mrlowndes @sdetweil
                @sdetweil yeah, no dice. This came up in my browser
                "title": "Data Unavailable For Requested Point",
                    "type": "https://api.weather.gov/problems/InvalidPoint",
                    "status": 404,
                    "detail": "Unable to provide data for requested point 34.5444,119.7913",
                    "instance": "https://api.weather.gov/requests/8199fbe2-ac6c-4c7c-b109-ed162794f780"
                  sdetweil @mrlowndes
                  @mrlowndes as I said, only works for US locations
                    mrlowndes
                    @sdetweil yeah, it is a US location
                      sdetweil @mrlowndes
                      @mrlowndes how can +119 be US location , mine is minus 97 (west of london)
                        mrlowndes
                        @sdetweil I’m using the lat long listed here: https://forecast.weather.gov/MapClick.php?lat=34.54167&lon=-119.80917#.XqhoOJp7kWr
                          sdetweil @mrlowndes
                          @mrlowndes u forgot the - sign
                          34.5444,119.7913",
                            mrlowndes
                            @sdetweil haha well that was dumb of me. I copied it from the web page where there isn’t a minus, but in the URL there obviously is. Thanks so much! got it working!
