    MM does not start anymore
    9 Posts 3 Posters 1.3k Views 3 Watching
    • V Offline
      Vauxdvihl
      Hello all,
      unfortunately my mm does not start anymore
      pi@PiMirrorNeu:~ $ pm2 start mm.sh
      [PM2] Applying action restartProcessId on app [mm](ids: 0,1)
      [PM2] [mm](0) ✓
      [PM2] [mm](1) ✓
      [PM2] Process successfully started
      │ id  │ na… │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
      │ 0   │ mm  │ default     │ N/A     │ fork    │ 2109     │ 0s     │ 1    │ online    │ 0%       │ 2.5mb    │ pi       │ disabled │
      │ 1   │ mm  │ default     │ 2.11.0  │ fork    │ 2118     │ 0      │ 32   │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
      pi@PiMirrorNeu:~ $ pm2 log
      /home/pi/.pm2/pm2.log last 15 lines:
      PM2        | 2020-04-28T15:13:35: PM2 log: App [mm:1] online
      PM2        | 2020-04-28T15:13:35: PM2 log: App [mm:1] exited with code [0] via signal [SIGINT]
      PM2        | 2020-04-28T15:13:35: PM2 log: App [mm:1] starting in -fork mode-
      PM2        | 2020-04-28T15:13:35: PM2 log: Script /home/pi/MagicMirror/mm.sh had too many unstable restarts (16). Stopped. "errored"
      Trying to install update, reports me the following error:
      pi@PiMirrorNeu:~/MagicMirror $ git pull && npm install
      Bereits aktuell.
      npm ERR! code ENOTDIR
      npm ERR! syscall scandir
      npm ERR! path /home/pi/MagicMirror/node_modules/rxjs/internal/operators/filter.d.ts
      npm ERR! errno -20
      npm ERR! ENOTDIR: not a directory, scandir '/home/pi/MagicMirror/node_modules/rxjs/internal/operators/filter.d.ts'
      npm ERR!     /home/pi/.npm/_logs/2020-04-28T13_28_36_996Z-debug.log
      Can please somebody help me
        sdetweil @Vauxdvihl
        @Vauxdvihl said in MM does not start anymore:
        yeh, such a mess
        also, erase the node_modules folder and package-lock.json files
        rm -rf node_modules
        AND for every module that has a package.json file, you must ALSO do npm install in THEIR folder.
        in the future, please use my upgrade script
        see here https://github.com/sdetweil/MagicMirror_scripts
        read the readme for the command to issue
        • bheplerB Offline
          bhepler Module Developer
          You also have two instances of Magic Mirror installed into PM2. Are you running both of these at the same time?
          • V Offline
            Vauxdvihl @bhepler
            @bhepler
            no
            i am not aware of this
            I only run on mm
            Regards
              sdetweil @Vauxdvihl
              @Vauxdvihl they are both called mm, 0 and 1…
              the messages from the log say you are using 1
              [mm:1] online
              try pm2 stop 0
              pm2 delete 1
              • V Offline
                Vauxdvihl @sdetweil
                Does not work
                Doing the other thing…i get an error message
                Operation not permitted…also with “sudo” in front
                pi@PiMirrorNeu:~/MagicMirror $ rm -rf node_modules/
                rm: das Entfernen von 'node_modules/rxjs/internal/operators/filter.d.ts' ist nicht möglich: Die Operation ist nicht erlaubt
                  sdetweil @Vauxdvihl
                  @Vauxdvihl sadly this means you are experiencing a problem with your SD card… I have lost 10 over the last couple years.
                  • V Offline
                    Vauxdvihl @sdetweil
                    I have erased the sd card and i have written a buster image on it
                    So far everthing works fine
                    Start know to install the mm again
                      sdetweil @Vauxdvihl
                      @Vauxdvihl use my script
                      for the command to execute
