    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp did you do the npm install in my module folder per the instructions?
      • PerlchampP
        Perlchamp
        shame on me. i didn’t install npm , tztztz …
        ok, now it works fine …
        the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
        how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
        how said, i’m a noob and i don’t know, if i can handle this all to manage.
        i want to code a small app, showing me the birthdays of the actual month. like this:
        maybe you can be my tutor, taking my hands and help me …
        so long
        many thanks in advance
        stay healthy
        keep corona away
          sdetweil @Perlchamp
          @Perlchamp said in read csv-data and put it in an array:
          there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
          I will answer questions and teach a little of the structure… I won’t write anything for you.
          • PerlchampP
            Perlchamp
            that’s not what i wanted (writing code for me). my big problem is, not to know how i can start, how i can test code-snippets and so on …
            i read some articles, but when i want to test some lines of code, i don’t know what to do. in my magicmirror module i can’t do that => error messages … i hope that i have expressed myself clearly and understandably …
            if i have a code-snoppet, go to terminal and put in
            node xxx.js
            path not found, module not found, and many other error messages … maybe i soon despair …
              sdetweil @Perlchamp
              @Perlchamp is the xxx.js in the current folder? if not u need to give path to the file
              you can do in MM module, with messages… there are two parts… the server side (node_helper) whose messages (console.log) come out on the same terminal window
              the browser side (modulename.js) uses Log.log. and displays only in the developer window
              I have modified a logging module that will display them together on the terminal window
              https://github.com/sdetweil/MMM-Logging
              install this as the FIRST module in the list
              use this definition in config.js
                          module: 'MMM-Logging',
                          disabled: false,
                              // Module functions out of the box with nothing set here.
                              // See below for configurable options.
                              echoLocal: true,
                              echoRemote: true,
                              overwriteBrowserMethods: true,
                              format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
              • PerlchampP
                Perlchamp
                thanks a lot, i will try to “play” with it. can take some time …
                  sdetweil @Perlchamp
                  @Perlchamp ok, if you are trying to use the csv-> somethign libraries and installed them in you module folder, then u want to be IN that folder to run your sample node xxx.js tests so the module folder path is right for require()
                  • PerlchampP
                    Perlchamp
                    @sdetweil said in read csv-data and put it in an array:
                    you mean in my module folder? it’s called “MMM-birthdaylist” …
                      sdetweil @Perlchamp
                      @Perlchamp correct
                      cd ~/MagicMirror/modules/MMM-birthdaylist
                      node xxx.js
                      note xxx.js can’t do anything specifically MagicMirror related no module register no sendSocketNotification
                      • PerlchampP
                        Perlchamp
                        ok, thanks a lot sam :-)
                        no i will try to play with it.
                        • PerlchampP
                          Perlchamp
                          Log.log("hello Log");
                          => Log.log(“hello Log”);
                          ReferenceError: Log is not defined
                          at Object. (/home/thomas/MagicMirror/modules/MMM-birthdaylist/test.js:1:1)
                          at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                          at startup (internal/bootstrap/node.js:283:19)
                          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                          console.log("hello console");
                          => hello console
                          • PerlchampP
                            Perlchamp
                            another question:
                            what can i do with MMM-logging. if i start npm start in the MagicMirror folder nothing will displayed. and to test, etc. i have to close MagicMirror because it fill the hole screen …
                              sdetweil @Perlchamp
                              @Perlchamp log.log only works in the modulename.js (the part loaded in the browser)
                              we call it that cause its filename matches the module name
                              • PerlchampP
                                Perlchamp
                                ok, thanks again :-)
                                  sdetweil @Perlchamp
                                  @Perlchamp u can redirect the output of npm start to a file, npm start >somefile
                                  u can minimize the window with alt-spacebar, n
                                  u can open the developers window ( for the modulename,js debugging) npm start dev
                                  or if mirror already running use f12 or ctrl-shift-i on the keyboard
                                  I debug from my PC, ssh connected to pi, or I run MM on my PC… and debug there
                                  • PerlchampP
                                    Perlchamp
                                    what do you use for debugging on pc ?
                                    do you have x64 or arm-based pc ?
                                      sdetweil @Perlchamp
                                      @Perlchamp x64, run linux or windows (today on linux), doesn’t matter… same debug process… look at console or browser window
                                      if I need to debug modulename.js on pi, I open browser from PC to the mirror URL and do it there
                                      • PerlchampP
                                        Perlchamp
                                        AND:
                                        thanks a lot for YOUR time. i hope it will not been wasted … i will working hard to get some results …
                                        • PerlchampP
                                          Perlchamp
                                          how ?
                                            sdetweil @Perlchamp
                                            @Perlchamp on MagicMirror, in config, set address:“0.0.0.0”,
                                            And ipWhitelist:[],
                                            Then u can connect to the mm url from anywhere in your house/office.
                                            http://ipaddress:port
                                            Then f12 or ctrl-shift-i on the browser keyboard to open the developers window.
                                            • 15
                                            • 16
                                            • 2 / 16
