    read csv-data and put it in an array
    313 Posts 3 Posters 494.6k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp you copied all this exactly, right?
      			module:"MyCovid19",
      			disabled:false,
      			position:"top_left",
      			classes: 'sam',
      			config:{
      				countries:["Italy","USA","China","Spain", "France",'Sweden'],
      				// line colors can be any definition of color either a name ,or a hex string
      				// one per country above, used in order,
      				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
      				chart_type:"cumulative_deaths",  // or "cumulative deaths"
      				chart_title:"cumulative deaths by country", // however u want to label
      				// the vertical steps on the chart.. how tall u want it to be and how mant increments
      				ranges:{min:0,max:30000,stepSize:5000},
      				// size of the chart in pixels
      			    width: 400,
      			    height: 400,
      			    // only used if we need to debug something
      			    debug:false,
      			    startDate:'02/01/2020',
      			    //backgroundColor: 'white',
      • PerlchampP Offline
        Perlchamp
        my config yet:
        			module:"MyCovid19",
        			disabled:false,
        			classes: 'sam',
        			config:{
        				countries:["Italy"],
        				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
        				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
        				line_colors:['white'],
        			    width: 400,
        			    height: 400,
        			    debug:false,
          sdetweil @Perlchamp
          @Perlchamp I used yours exactly, and works
            Perlchamp
            may it need time to load the raw data?
            i will start it, drink a coffee, will come back and see …
              sdetweil @Perlchamp
              @Perlchamp raw data is the csv file from the source
              it should be there within a few seconds…
                I will be busy for next few hours with grandson
                  Perlchamp
                  my old config doesn’t go either. something’s wrong. but what ?
                    sdetweil @Perlchamp
                    @Perlchamp did you do the npm install in my module folder per the instructions?
                      Perlchamp
                      shame on me. i didn’t install npm , tztztz …
                      ok, now it works fine …
                      the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
                      how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
                      how said, i’m a noob and i don’t know, if i can handle this all to manage.
                      i want to code a small app, showing me the birthdays of the actual month. like this:
                      maybe you can be my tutor, taking my hands and help me …
                      so long
                      many thanks in advance
                      stay healthy
                      keep corona away
                        sdetweil @Perlchamp
                        @Perlchamp said in read csv-data and put it in an array:
                        there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
                        I will answer questions and teach a little of the structure… I won’t write anything for you.
                        • 31
                        • 32
                        • 3 / 32
