    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp raw data is the csv file from the source
      it should be there within a few seconds…
        I will be busy for next few hours with grandson
        • PerlchampP Offline
          Perlchamp
          my old config doesn’t go either. something’s wrong. but what ?
            sdetweil @Perlchamp
            @Perlchamp did you do the npm install in my module folder per the instructions?
              Perlchamp
              shame on me. i didn’t install npm , tztztz …
              ok, now it works fine …
              the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
              how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
              how said, i’m a noob and i don’t know, if i can handle this all to manage.
              i want to code a small app, showing me the birthdays of the actual month. like this:
              maybe you can be my tutor, taking my hands and help me …
              so long
              many thanks in advance
              stay healthy
              keep corona away
                sdetweil @Perlchamp
                @Perlchamp said in read csv-data and put it in an array:
                there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
                I will answer questions and teach a little of the structure… I won’t write anything for you.
                  Perlchamp
                  that’s not what i wanted (writing code for me). my big problem is, not to know how i can start, how i can test code-snippets and so on …
                  i read some articles, but when i want to test some lines of code, i don’t know what to do. in my magicmirror module i can’t do that => error messages … i hope that i have expressed myself clearly and understandably …
                  if i have a code-snoppet, go to terminal and put in
                  node xxx.js
                  path not found, module not found, and many other error messages … maybe i soon despair …
                    sdetweil @Perlchamp
                    @Perlchamp is the xxx.js in the current folder? if not u need to give path to the file
                    you can do in MM module, with messages… there are two parts… the server side (node_helper) whose messages (console.log) come out on the same terminal window
                    the browser side (modulename.js) uses Log.log. and displays only in the developer window
                    I have modified a logging module that will display them together on the terminal window
                    https://github.com/sdetweil/MMM-Logging
                    install this as the FIRST module in the list
                    use this definition in config.js
                                module: 'MMM-Logging',
                                disabled: false,
                                    // Module functions out of the box with nothing set here.
                                    // See below for configurable options.
                                    echoLocal: true,
                                    echoRemote: true,
                                    overwriteBrowserMethods: true,
                                    format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                      Perlchamp
                      thanks a lot, i will try to “play” with it. can take some time …
                        sdetweil @Perlchamp
                        @Perlchamp ok, if you are trying to use the csv-> somethign libraries and installed them in you module folder, then u want to be IN that folder to run your sample node xxx.js tests so the module folder path is right for require()
                          Perlchamp
                          @sdetweil said in read csv-data and put it in an array:
                          you mean in my module folder? it’s called “MMM-birthdaylist” …
                            sdetweil @Perlchamp
                            @Perlchamp correct
                            cd ~/MagicMirror/modules/MMM-birthdaylist
                            node xxx.js
                            note xxx.js can’t do anything specifically MagicMirror related no module register no sendSocketNotification
                              Perlchamp
                              ok, thanks a lot sam :-)
                              no i will try to play with it.
                                Perlchamp
                                Log.log("hello Log");
                                => Log.log(“hello Log”);
                                ReferenceError: Log is not defined
                                at Object. (/home/thomas/MagicMirror/modules/MMM-birthdaylist/test.js:1:1)
                                at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                at startup (internal/bootstrap/node.js:283:19)
                                at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                console.log("hello console");
                                => hello console
                                  Perlchamp
                                  another question:
                                  what can i do with MMM-logging. if i start npm start in the MagicMirror folder nothing will displayed. and to test, etc. i have to close MagicMirror because it fill the hole screen …
                                    sdetweil @Perlchamp
                                    @Perlchamp log.log only works in the modulename.js (the part loaded in the browser)
                                    we call it that cause its filename matches the module name
                                      Perlchamp
                                      ok, thanks again :-)
                                        sdetweil @Perlchamp
                                        @Perlchamp u can redirect the output of npm start to a file, npm start >somefile
                                        u can minimize the window with alt-spacebar, n
                                        u can open the developers window ( for the modulename,js debugging) npm start dev
                                        or if mirror already running use f12 or ctrl-shift-i on the keyboard
                                        I debug from my PC, ssh connected to pi, or I run MM on my PC… and debug there
                                          Perlchamp
                                          what do you use for debugging on pc ?
                                          do you have x64 or arm-based pc ?
                                            sdetweil @Perlchamp
                                            @Perlchamp x64, run linux or windows (today on linux), doesn’t matter… same debug process… look at console or browser window
                                            if I need to debug modulename.js on pi, I open browser from PC to the mirror URL and do it there
                                            • 15
                                            • 16
                                            • 2 / 16
