    read csv-data and put it in an array
    313 Posts 3 Posters 530.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp no… see the node_helper.js
      you cannot use the csvtojson in the modulename.js
        sdetweil @Perlchamp
        @Perlchamp did u use my config info above? just to make it work
        • PerlchampP Offline
          Perlchamp
          yes.
          [“Italy”],
          which one? in your corona ?
            sdetweil @Perlchamp
            @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
              Perlchamp
              i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
                sdetweil @Perlchamp
                @Perlchamp you copied all this exactly, right?
                			module:"MyCovid19",
                			disabled:false,
                			position:"top_left",
                			classes: 'sam',
                			config:{
                				countries:["Italy","USA","China","Spain", "France",'Sweden'],
                				// line colors can be any definition of color either a name ,or a hex string
                				// one per country above, used in order,
                				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                				chart_type:"cumulative_deaths",  // or "cumulative deaths"
                				chart_title:"cumulative deaths by country", // however u want to label
                				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                				ranges:{min:0,max:30000,stepSize:5000},
                				// size of the chart in pixels
                			    width: 400,
                			    height: 400,
                			    // only used if we need to debug something
                			    debug:false,
                			    startDate:'02/01/2020',
                			    //backgroundColor: 'white',
                  Perlchamp
                  my config yet:
                  			module:"MyCovid19",
                  			disabled:false,
                  			classes: 'sam',
                  			config:{
                  				countries:["Italy"],
                  				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
                  				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                  				line_colors:['white'],
                  			    width: 400,
                  			    height: 400,
                  			    debug:false,
                    sdetweil @Perlchamp
                    @Perlchamp I used yours exactly, and works
                      Perlchamp
                      may it need time to load the raw data?
                      i will start it, drink a coffee, will come back and see …
                        sdetweil @Perlchamp
                        @Perlchamp raw data is the csv file from the source
                        it should be there within a few seconds…
                          I will be busy for next few hours with grandson
                            Perlchamp
                            my old config doesn’t go either. something’s wrong. but what ?
                              sdetweil @Perlchamp
                              @Perlchamp did you do the npm install in my module folder per the instructions?
                                Perlchamp
                                shame on me. i didn’t install npm , tztztz …
                                ok, now it works fine …
                                the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
                                how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
                                how said, i’m a noob and i don’t know, if i can handle this all to manage.
                                i want to code a small app, showing me the birthdays of the actual month. like this:
                                maybe you can be my tutor, taking my hands and help me …
                                so long
                                many thanks in advance
                                stay healthy
                                keep corona away
                                  sdetweil @Perlchamp
                                  @Perlchamp said in read csv-data and put it in an array:
                                  there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
                                  I will answer questions and teach a little of the structure… I won’t write anything for you.
                                    Perlchamp
                                    that’s not what i wanted (writing code for me). my big problem is, not to know how i can start, how i can test code-snippets and so on …
                                    i read some articles, but when i want to test some lines of code, i don’t know what to do. in my magicmirror module i can’t do that => error messages … i hope that i have expressed myself clearly and understandably …
                                    if i have a code-snoppet, go to terminal and put in
                                    node xxx.js
                                    path not found, module not found, and many other error messages … maybe i soon despair …
                                      sdetweil @Perlchamp
                                      @Perlchamp is the xxx.js in the current folder? if not u need to give path to the file
                                      you can do in MM module, with messages… there are two parts… the server side (node_helper) whose messages (console.log) come out on the same terminal window
                                      the browser side (modulename.js) uses Log.log. and displays only in the developer window
                                      I have modified a logging module that will display them together on the terminal window
                                      https://github.com/sdetweil/MMM-Logging
                                      install this as the FIRST module in the list
                                      use this definition in config.js
                                                  module: 'MMM-Logging',
                                                  disabled: false,
                                                      // Module functions out of the box with nothing set here.
                                                      // See below for configurable options.
                                                      echoLocal: true,
                                                      echoRemote: true,
                                                      overwriteBrowserMethods: true,
                                                      format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                                        Perlchamp
                                        thanks a lot, i will try to “play” with it. can take some time …
                                          sdetweil @Perlchamp
                                          @Perlchamp ok, if you are trying to use the csv-> somethign libraries and installed them in you module folder, then u want to be IN that folder to run your sample node xxx.js tests so the module folder path is right for require()
                                            Perlchamp
                                            @sdetweil said in read csv-data and put it in an array:
                                            you mean in my module folder? it’s called “MMM-birthdaylist” …
                                            • 15
                                            • 16
                                            • 2 / 16
