    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
      • PerlchampP
        Perlchamp
        i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
          sdetweil @Perlchamp
          @Perlchamp you copied all this exactly, right?
          			module:"MyCovid19",
          			disabled:false,
          			position:"top_left",
          			classes: 'sam',
          			config:{
          				countries:["Italy","USA","China","Spain", "France",'Sweden'],
          				// line colors can be any definition of color either a name ,or a hex string
          				// one per country above, used in order,
          				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
          				chart_type:"cumulative_deaths",  // or "cumulative deaths"
          				chart_title:"cumulative deaths by country", // however u want to label
          				// the vertical steps on the chart.. how tall u want it to be and how mant increments
          				ranges:{min:0,max:30000,stepSize:5000},
          				// size of the chart in pixels
          			    width: 400,
          			    height: 400,
          			    // only used if we need to debug something
          			    debug:false,
          			    startDate:'02/01/2020',
          			    //backgroundColor: 'white',
          • PerlchampP
            Perlchamp
            my config yet:
            			module:"MyCovid19",
            			disabled:false,
            			classes: 'sam',
            			config:{
            				countries:["Italy"],
            				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
            				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
            				line_colors:['white'],
            			    width: 400,
            			    height: 400,
            			    debug:false,
              sdetweil @Perlchamp
              @Perlchamp I used yours exactly, and works
              • PerlchampP
                Perlchamp
                may it need time to load the raw data?
                i will start it, drink a coffee, will come back and see …
                  sdetweil @Perlchamp
                  @Perlchamp raw data is the csv file from the source
                  it should be there within a few seconds…
                    I will be busy for next few hours with grandson
                    • PerlchampP
                      Perlchamp
                      my old config doesn’t go either. something’s wrong. but what ?
                        sdetweil @Perlchamp
                        @Perlchamp did you do the npm install in my module folder per the instructions?
                        • PerlchampP
                          Perlchamp
                          shame on me. i didn’t install npm , tztztz …
                          ok, now it works fine …
                          the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
                          how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
                          how said, i’m a noob and i don’t know, if i can handle this all to manage.
                          i want to code a small app, showing me the birthdays of the actual month. like this:
                          maybe you can be my tutor, taking my hands and help me …
                          so long
                          many thanks in advance
                          stay healthy
                          keep corona away
                            sdetweil @Perlchamp
                            @Perlchamp said in read csv-data and put it in an array:
                            there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
                            I will answer questions and teach a little of the structure… I won’t write anything for you.
                            • PerlchampP
                              Perlchamp
                              that’s not what i wanted (writing code for me). my big problem is, not to know how i can start, how i can test code-snippets and so on …
                              i read some articles, but when i want to test some lines of code, i don’t know what to do. in my magicmirror module i can’t do that => error messages … i hope that i have expressed myself clearly and understandably …
                              if i have a code-snoppet, go to terminal and put in
                              node xxx.js
                              path not found, module not found, and many other error messages … maybe i soon despair …
                                sdetweil @Perlchamp
                                @Perlchamp is the xxx.js in the current folder? if not u need to give path to the file
                                you can do in MM module, with messages… there are two parts… the server side (node_helper) whose messages (console.log) come out on the same terminal window
                                the browser side (modulename.js) uses Log.log. and displays only in the developer window
                                I have modified a logging module that will display them together on the terminal window
                                https://github.com/sdetweil/MMM-Logging
                                install this as the FIRST module in the list
                                use this definition in config.js
                                            module: 'MMM-Logging',
                                            disabled: false,
                                                // Module functions out of the box with nothing set here.
                                                // See below for configurable options.
                                                echoLocal: true,
                                                echoRemote: true,
                                                overwriteBrowserMethods: true,
                                                format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                                • PerlchampP
                                  Perlchamp
                                  thanks a lot, i will try to “play” with it. can take some time …
                                    sdetweil @Perlchamp
                                    @Perlchamp ok, if you are trying to use the csv-> somethign libraries and installed them in you module folder, then u want to be IN that folder to run your sample node xxx.js tests so the module folder path is right for require()
                                    • PerlchampP
                                      Perlchamp
                                      @sdetweil said in read csv-data and put it in an array:
                                      you mean in my module folder? it’s called “MMM-birthdaylist” …
                                        sdetweil @Perlchamp
                                        @Perlchamp correct
                                        cd ~/MagicMirror/modules/MMM-birthdaylist
                                        node xxx.js
                                        note xxx.js can’t do anything specifically MagicMirror related no module register no sendSocketNotification
                                        • PerlchampP
                                          Perlchamp
                                          ok, thanks a lot sam :-)
                                          no i will try to play with it.
                                          • PerlchampP
                                            Perlchamp
                                            Log.log("hello Log");
                                            => Log.log(“hello Log”);
                                            ReferenceError: Log is not defined
                                            at Object. (/home/thomas/MagicMirror/modules/MMM-birthdaylist/test.js:1:1)
                                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                            at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                            at startup (internal/bootstrap/node.js:283:19)
                                            at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                            console.log("hello console");
                                            => hello console
                                            • 15
                                            • 16
                                            • 2 / 16
