    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp show me the config for the module?
      • PerlchampP
        Perlchamp
        in config.js i didn’t use the config section. i thought the defaults should be enough. ok, i will put the config section into the config.js. just a moment, please …
          sdetweil @Perlchamp
          @Perlchamp no… I don’t pick any countries or states, or describe how big the charts should be…
          try this
          			module:"MyCovid19",
          			disabled:false,
          			position:"top_left",
          			classes: 'sam',
          			config:{
          				countries:["Italy","USA","China","Spain", "France",'Sweden'],
          				// line colors can be any definition of color either a name ,or a hex string
          				// one per country above, used in order,
          				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
          				chart_type:"cumulative_deaths",  // or "cumulative deaths"
          				chart_title:"cumulative deaths by country", // however u want to label
          				// the vertical steps on the chart.. how tall u want it to be and how mant increments
          				ranges:{min:0,max:30000,stepSize:5000},
          				// size of the chart in pixels
          			    width: 400,
          			    height: 400,
          			    // only used if we need to debug something
          			    debug:false,
          			    startDate:'02/01/2020',
          			    //backgroundColor: 'white',
          • PerlchampP
            Perlchamp
            still loading …
            			module: "MyCovid19",
            			config:{
            				countries: "Italy",
            			    //countries:["Italy","USA","China","Spain","France"],
                            //OR
            			    //states:['New York','Illinois','Texas'],
            			    // one of countries or states MUST be specified
            			    //line_colors:['red','white','green','yellow','blue'],
            			    line_colors: "white",
            			    chart_type:"cumulative_cases",  // or "cumulative deaths"
            			    chart_title:"Cumulative Cases", // however u want to label
            			    ranges:{min:0,max:8000,stepSize:10000},
            		        width: 400,
            		        height: 500,
            		        debug:false,
            		        startDate: "02/01/2020"
              sdetweil @Perlchamp
              @Perlchamp said in read csv-data and put it in an array:
                		countries: "Italy",
              must be an array countries : [ ‘Italy’ ] ,
              • PerlchampP
                Perlchamp
                to include csvtojson i have to do the following ?
                getScripts: function () {
                		    return ["moment.js", "modules/" + this.name + "/node_modules/csvtojson/bin/csvtojson.js"];
                is that right ?
                covid do not run … black screen, no loading message …
                  sdetweil @Perlchamp
                  @Perlchamp no… see the node_helper.js
                  you cannot use the csvtojson in the modulename.js
                    sdetweil @Perlchamp
                    @Perlchamp did u use my config info above? just to make it work
                    • PerlchampP
                      Perlchamp
                      yes.
                      [“Italy”],
                      which one? in your corona ?
                        sdetweil @Perlchamp
                        @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
                        • PerlchampP
                          Perlchamp
                          i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
                            sdetweil @Perlchamp
                            @Perlchamp you copied all this exactly, right?
                            			module:"MyCovid19",
                            			disabled:false,
                            			classes: 'sam',
                            			config:{
                            			    width: 400,
                            			    height: 400,
                            			    debug:false,
                            • PerlchampP
                              Perlchamp
                              my config yet:
                              			module:"MyCovid19",
                              			disabled:false,
                              			classes: 'sam',
                              			config:{
                              				countries:["Italy"],
                              				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
                              				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                              				line_colors:['white'],
                              			    width: 400,
                              			    height: 400,
                              			    debug:false,
                                sdetweil @Perlchamp
                                @Perlchamp I used yours exactly, and works
                                • PerlchampP
                                  Perlchamp
                                  may it need time to load the raw data?
                                  i will start it, drink a coffee, will come back and see …
                                    sdetweil @Perlchamp
                                    @Perlchamp raw data is the csv file from the source
                                    it should be there within a few seconds…
                                      I will be busy for next few hours with grandson
                                      • PerlchampP
                                        Perlchamp
                                        my old config doesn’t go either. something’s wrong. but what ?
                                          sdetweil @Perlchamp
                                          @Perlchamp did you do the npm install in my module folder per the instructions?
                                          • PerlchampP
                                            Perlchamp
                                            shame on me. i didn’t install npm , tztztz …
                                            ok, now it works fine …
                                            the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
                                            how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
                                            how said, i’m a noob and i don’t know, if i can handle this all to manage.
                                            i want to code a small app, showing me the birthdays of the actual month. like this:
                                            maybe you can be my tutor, taking my hands and help me …
                                            so long
                                            many thanks in advance
                                            stay healthy
                                            keep corona away
                                            • 15
                                            • 16
                                            • 1 / 16
