    read csv-data and put it in an array
    313 Posts 3 Posters 590.2k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp my sample module might be helpful too…
      https://github.com/sdetweil/SampleModule
      implements what is in the developing module documentation
      https://docs.magicmirror.builders/development/introduction.html
      • PerlchampP
        Perlchamp
        hello sam,
        thanks a lot. i will have a look on it, too. sure, i will learn a lot.
        so long
        • PerlchampP
          Perlchamp
          covid chart do not load :-(
            sdetweil @Perlchamp
            @Perlchamp show me the config for the module?
            • PerlchampP
              Perlchamp
              in config.js i didn’t use the config section. i thought the defaults should be enough. ok, i will put the config section into the config.js. just a moment, please …
                sdetweil @Perlchamp
                @Perlchamp no… I don’t pick any countries or states, or describe how big the charts should be…
                try this
                			module:"MyCovid19",
                			disabled:false,
                			position:"top_left",
                			classes: 'sam',
                			config:{
                				countries:["Italy","USA","China","Spain", "France",'Sweden'],
                				// line colors can be any definition of color either a name ,or a hex string
                				// one per country above, used in order,
                				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                				chart_type:"cumulative_deaths",  // or "cumulative deaths"
                				chart_title:"cumulative deaths by country", // however u want to label
                				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                				ranges:{min:0,max:30000,stepSize:5000},
                				// size of the chart in pixels
                			    width: 400,
                			    height: 400,
                			    // only used if we need to debug something
                			    debug:false,
                			    startDate:'02/01/2020',
                			    //backgroundColor: 'white',
                • PerlchampP
                  Perlchamp
                  still loading …
                  			module: "MyCovid19",
                  			config:{
                  				countries: "Italy",
                  			    //countries:["Italy","USA","China","Spain","France"],
                                  //OR
                  			    //states:['New York','Illinois','Texas'],
                  			    // one of countries or states MUST be specified
                  			    //line_colors:['red','white','green','yellow','blue'],
                  			    line_colors: "white",
                  			    chart_type:"cumulative_cases",  // or "cumulative deaths"
                  			    chart_title:"Cumulative Cases", // however u want to label
                  			    ranges:{min:0,max:8000,stepSize:10000},
                  		        width: 400,
                  		        height: 500,
                  		        debug:false,
                  		        startDate: "02/01/2020"
                    sdetweil @Perlchamp
                    @Perlchamp said in read csv-data and put it in an array:
                      		countries: "Italy",
                    must be an array countries : [ ‘Italy’ ] ,
                    • PerlchampP
                      Perlchamp
                      to include csvtojson i have to do the following ?
                      getScripts: function () {
                      		    return ["moment.js", "modules/" + this.name + "/node_modules/csvtojson/bin/csvtojson.js"];
                      is that right ?
                      covid do not run … black screen, no loading message …
                      S 2 Replies Last reply
                        sdetweil @Perlchamp
                        @Perlchamp no… see the node_helper.js
                        you cannot use the csvtojson in the modulename.js
                          sdetweil @Perlchamp
                          @Perlchamp did u use my config info above? just to make it work
                          • PerlchampP
                            Perlchamp
                            yes.
                            [“Italy”],
                            which one? in your corona ?
                              sdetweil @Perlchamp
                              @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
                              • PerlchampP
                                Perlchamp
                                i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
                                  sdetweil @Perlchamp
                                  @Perlchamp you copied all this exactly, right?
                                  			module:"MyCovid19",
                                  			disabled:false,
                                  			classes: 'sam',
                                  			config:{
                                  			    width: 400,
                                  			    height: 400,
                                  			    debug:false,
                                  • PerlchampP
                                    Perlchamp
                                    my config yet:
                                    			module:"MyCovid19",
                                    			disabled:false,
                                    			classes: 'sam',
                                    			config:{
                                    				countries:["Italy"],
                                    				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
                                    				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                                    				line_colors:['white'],
                                    			    width: 400,
                                    			    height: 400,
                                    			    debug:false,
                                      sdetweil @Perlchamp
                                      @Perlchamp I used yours exactly, and works
                                      • PerlchampP
                                        Perlchamp
                                        may it need time to load the raw data?
                                        i will start it, drink a coffee, will come back and see …
                                          sdetweil @Perlchamp
                                          @Perlchamp raw data is the csv file from the source
                                          it should be there within a few seconds…
                                            I will be busy for next few hours with grandson
                                            • 15
                                            • 16
                                            • 1 / 16
