    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp you have to use the node_helper.js … the module.js file runs in the browser and doesn’t have access to local files
      var xxx= require(‘’)…
      then module has to send request to node_helper and node_helper has to send results back
      see my MyCovid19 module
      https://github.com/sdetweil/MyCovid19
      • PerlchampP Offline
        Perlchamp
        hello sam,
        i’m a noob. sorry for that. i will have a look to your module.
        this all is new for me. it will take some time …
        if you would help me, that would be great. but first i have to read some things …
        so long
          sdetweil @Perlchamp
          @Perlchamp my sample module might be helpful too…
          https://github.com/sdetweil/SampleModule
          implements what is in the developing module documentation
          https://docs.magicmirror.builders/development/introduction.html
            Perlchamp
            hello sam,
            thanks a lot. i will have a look on it, too. sure, i will learn a lot.
            so long
              Perlchamp
              covid chart do not load :-(
                sdetweil @Perlchamp
                @Perlchamp show me the config for the module?
                  Perlchamp
                  in config.js i didn’t use the config section. i thought the defaults should be enough. ok, i will put the config section into the config.js. just a moment, please …
                    sdetweil @Perlchamp
                    @Perlchamp no… I don’t pick any countries or states, or describe how big the charts should be…
                    try this
                    			module:"MyCovid19",
                    			disabled:false,
                    			position:"top_left",
                    			classes: 'sam',
                    			config:{
                    				countries:["Italy","USA","China","Spain", "France",'Sweden'],
                    				// line colors can be any definition of color either a name ,or a hex string
                    				// one per country above, used in order,
                    				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                    				chart_type:"cumulative_deaths",  // or "cumulative deaths"
                    				chart_title:"cumulative deaths by country", // however u want to label
                    				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                    				ranges:{min:0,max:30000,stepSize:5000},
                    				// size of the chart in pixels
                    			    width: 400,
                    			    height: 400,
                    			    // only used if we need to debug something
                    			    debug:false,
                    			    startDate:'02/01/2020',
                    			    //backgroundColor: 'white',
                      Perlchamp
                      still loading …
                      			module: "MyCovid19",
                      			config:{
                      				countries: "Italy",
                      			    //countries:["Italy","USA","China","Spain","France"],
                                      //OR
                      			    //states:['New York','Illinois','Texas'],
                      			    // one of countries or states MUST be specified
                      			    //line_colors:['red','white','green','yellow','blue'],
                      			    line_colors: "white",
                      			    chart_type:"cumulative_cases",  // or "cumulative deaths"
                      			    chart_title:"Cumulative Cases", // however u want to label
                      			    ranges:{min:0,max:8000,stepSize:10000},
                      		        width: 400,
                      		        height: 500,
                      		        debug:false,
                      		        startDate: "02/01/2020"
                        sdetweil @Perlchamp
                        @Perlchamp said in read csv-data and put it in an array:
                          		countries: "Italy",
                        must be an array countries : [ ‘Italy’ ] ,
                          Perlchamp
                          to include csvtojson i have to do the following ?
                          getScripts: function () {
                          		    return ["moment.js", "modules/" + this.name + "/node_modules/csvtojson/bin/csvtojson.js"];
                          is that right ?
                          covid do not run … black screen, no loading message …
                            sdetweil @Perlchamp
                            @Perlchamp no… see the node_helper.js
                            you cannot use the csvtojson in the modulename.js
                              sdetweil @Perlchamp
                              @Perlchamp did u use my config info above? just to make it work
                                Perlchamp
                                yes.
                                [“Italy”],
                                which one? in your corona ?
                                  sdetweil @Perlchamp
                                  @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
                                    Perlchamp
                                    i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
                                      sdetweil @Perlchamp
                                      @Perlchamp you copied all this exactly, right?
                                      			module:"MyCovid19",
                                      			disabled:false,
                                      			classes: 'sam',
                                      			config:{
                                      			    width: 400,
                                      			    height: 400,
                                      			    debug:false,
                                        Perlchamp
                                        my config yet:
                                        			module:"MyCovid19",
                                        			disabled:false,
                                        			classes: 'sam',
                                        			config:{
                                        				countries:["Italy"],
                                        				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
                                        				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                                        				line_colors:['white'],
                                        			    width: 400,
                                        			    height: 400,
                                        			    debug:false,
                                          sdetweil @Perlchamp
                                          @Perlchamp I used yours exactly, and works
                                            Perlchamp
                                            may it need time to load the raw data?
                                            i will start it, drink a coffee, will come back and see …
                                            • 15
                                            • 16
                                            • 1 / 16
