    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      still loading …
      			module: "MyCovid19",
      			config:{
      				countries: "Italy",
      			    //countries:["Italy","USA","China","Spain","France"],
                      //OR
      			    //states:['New York','Illinois','Texas'],
      			    // one of countries or states MUST be specified
      			    // line colors can be any definition of color either a name ,or a hex string
      			    // one per country above, used in order,
      			    //line_colors:['red','white','green','yellow','blue'],
      			    line_colors: "white",
      			    chart_type:"cumulative_cases",  // or "cumulative deaths"
      			    chart_title:"Cumulative Cases", // however u want to label
      			    // the vertical steps on the chart.. how tall u want it to be and how mant increments
      			    ranges:{min:0,max:8000,stepSize:10000},
      			    // size of the chart in pixels
      		        width: 400,
      		        height: 500,
      		        // only used if we need to debug something
      		        debug:false,
      		        startDate: "02/01/2020"
        sdetweil @Perlchamp
        @Perlchamp said in read csv-data and put it in an array:
          		countries: "Italy",
        must be an array countries : [ ‘Italy’ ] ,
          Perlchamp
          to include csvtojson i have to do the following ?
          getScripts: function () {
          		    return ["moment.js", "modules/" + this.name + "/node_modules/csvtojson/bin/csvtojson.js"];
          is that right ?
          covid do not run … black screen, no loading message …
            sdetweil @Perlchamp
            @Perlchamp no… see the node_helper.js
            you cannot use the csvtojson in the modulename.js
              sdetweil @Perlchamp
              @Perlchamp did u use my config info above? just to make it work
                Perlchamp
                yes.
                [“Italy”],
                which one? in your corona ?
                  sdetweil @Perlchamp
                  @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
                    Perlchamp
                    i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
                      sdetweil @Perlchamp
                      @Perlchamp you copied all this exactly, right?
                      			module:"MyCovid19",
                      			disabled:false,
                      			position:"top_left",
                      			classes: 'sam',
                      			config:{
                      				countries:["Italy","USA","China","Spain", "France",'Sweden'],
                      				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                      				chart_type:"cumulative_deaths",  // or "cumulative deaths"
                      				chart_title:"cumulative deaths by country", // however u want to label
                      				ranges:{min:0,max:30000,stepSize:5000},
                      			    width: 400,
                      			    height: 400,
                      			    debug:false,
                      			    startDate:'02/01/2020',
                      			    //backgroundColor: 'white',
                        Perlchamp
                        my config yet:
                        			module:"MyCovid19",
                        			disabled:false,
                        			classes: 'sam',
                        			config:{
                        				countries:["Italy"],
                        				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
                        				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                        				line_colors:['white'],
                        			    width: 400,
                        			    height: 400,
                        			    debug:false,
                          sdetweil @Perlchamp
                          @Perlchamp I used yours exactly, and works
                            Perlchamp
                            may it need time to load the raw data?
                            i will start it, drink a coffee, will come back and see …
                              sdetweil @Perlchamp
                              @Perlchamp raw data is the csv file from the source
                              it should be there within a few seconds…
                                I will be busy for next few hours with grandson
                                  Perlchamp
                                  my old config doesn’t go either. something’s wrong. but what ?
                                    sdetweil @Perlchamp
                                    @Perlchamp did you do the npm install in my module folder per the instructions?
                                      Perlchamp
                                      shame on me. i didn’t install npm , tztztz …
                                      ok, now it works fine …
                                      the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
                                      how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
                                      how said, i’m a noob and i don’t know, if i can handle this all to manage.
                                      i want to code a small app, showing me the birthdays of the actual month. like this:
                                      maybe you can be my tutor, taking my hands and help me …
                                      so long
                                      many thanks in advance
                                      stay healthy
                                      keep corona away
                                        sdetweil @Perlchamp
                                        there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
                                        I will answer questions and teach a little of the structure… I won’t write anything for you.
                                          Perlchamp
                                          that’s not what i wanted (writing code for me). my big problem is, not to know how i can start, how i can test code-snippets and so on …
                                          i read some articles, but when i want to test some lines of code, i don’t know what to do. in my magicmirror module i can’t do that => error messages … i hope that i have expressed myself clearly and understandably …
                                          if i have a code-snoppet, go to terminal and put in
                                          node xxx.js
                                          path not found, module not found, and many other error messages … maybe i soon despair …
                                            sdetweil @Perlchamp
                                            @Perlchamp is the xxx.js in the current folder? if not u need to give path to the file
                                            you can do in MM module, with messages… there are two parts… the server side (node_helper) whose messages (console.log) come out on the same terminal window
                                            the browser side (modulename.js) uses Log.log. and displays only in the developer window
                                            I have modified a logging module that will display them together on the terminal window
                                            https://github.com/sdetweil/MMM-Logging
                                            install this as the FIRST module in the list
                                            use this definition in config.js
                                                        module: 'MMM-Logging',
                                                        disabled: false,
                                                            // Module functions out of the box with nothing set here.
                                                            // See below for configurable options.
                                                            echoLocal: true,
                                                            echoRemote: true,
                                                            overwriteBrowserMethods: true,
                                                            format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                                            • 15
                                            • 16
                                            • 2 / 16
