    MMM-PIR - off delay
    11 Posts 5 Posters 9.9k Views 6 Watching
      JamesMM
      Thanks for your pointers.
      So clearTimeout will throw an error because self.timer is not defined so I defined it as null at the top, and didn’t bother checking if it was null or not before clearing it.
      Once this was done we were in the same boat as before with a pir detection of 1 before the timeout has fired resulting in the mirror turning off and on again which is annoying. This is fixed by adding an onstate variable and simply not executing the activatemirror if its already activated. I just moved cleartimeout outside of that check otherwise it won’t work.
      My working code below since I find it annoying when people don’t come back when they solve a problem:
      // Subclass socketNotificationReceived received.
      if (notification === ‘CONFIG’ && this.started == false) {
      const self = this;
      this.config = payload;
      self.timer = null;
      self.onState = 0;
        //Log.info('PIR: ' + this.name);
        //Setup pins
        this.pir = new Gpio(this.config.sensorPIN, 'in', 'both');
        if (this.config.relayPIN) {
          this.relay = new Gpio(this.config.relayPIN, 'out');
          this.relay.writeSync(this.config.relayOnState);
          exec("/opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7", null);
        //Detected movement
        this.pir.watch(function(err, value) {
          if (value == 1) {
           clearTimeout(self.timer);
          if(self.onState != 1){
            self.sendSocketNotification("USER_PRESENCE", true);
            if (self.config.powerSaving){
              self.activateMonitor();
              self.onState = 1;
          else if (value == 0) {
            if(self.onState != 0){
             self.timer = setTimeout(function(){
                self.sendSocketNotification("USER_PRESENCE", false);
                  self.deactivateMonitor();
                  self.onState = 0;
            }, self.config.offDelay);
        this.started = true;
      } else if (notification === 'SCREEN_WAKEUP') {
        this.activateMonitor();
        JamesMM
        Sorry I didn’t quote the code properly.
          bibi @JamesMM
          @JamesMM hi! i also have pain to setup the PIR in hardware way and i would prefer your way. Is the code stated above working? thx
          • L Offline
            lsfourwheeler
            @JamesMM Where is the “Config” section where you added the delay configuration? I’ve changed my node_helper.js file but I can’t find the configuration file you referenced.
            • L Offline
              lsfourwheeler @lsfourwheeler
              @lsfourwheeler @JamesMM Actually, I see that you are referencing the Magic Mirror config for the delay setting. So where are you replacing the deactivateMonitor with timerID?
                JamesMM @bibi
                @bibi it does. Perfectly.
                  JamesMM @lsfourwheeler
                  @lsfourwheeler yes passed it in. Assumed that was how it was supposed to be done.
                    bibi @JamesMM
                    @JamesMM ok thx! i don’t really get where exactly your code above should be placed :( can you give me a hint pls?
                    • troelsbuggeT Offline
                      troelsbugge
                      Thank you for sharing @JamesMM - it works perfectly!
