    Hourly weather forecast
    13 Posts 5 Posters 3.5k Views 4 Watching
      mrlowndes
      Hey, I know that providers are dropping API support like dead flies but I’m wondering if there are any weather modules that do good hourly forecasts? Looked at MM-NOAA3 but it doesn’t seem to do hourly
        A Former User
          mrlowndes
          @hango cool. Sorry, I’m a noob. When you say make modification in js file, do you mean the config.js, or the js file for the module?
            mrlowndes
            @hango ok got it working, do you know how I would remove temperature?
              mrlowndes
              @hango Also, it is currently 13:14 and the first time in the hourly forecast is 21:00 - how do I shift it to show the 6 hours immediately after this current time? I also don’t need min and max temperature for each hour so I would like to remove those to de-clutter the space. Any tips?
                A Former User
                  mrlowndes
                  @hango I make wildlife documentaries so knowing what hour the weather is going to change from sunny to overcast, for example, would be really useful. Every 3 hours is much less useful, especially if it’s only showing my the weather every three hours after the sun has set. I can’t think of anyone would need the min and max temp hourly. Generally, the temperature on any given day reaches it’s peak 2-3 hours after the sun has reached its zenith, and its coolest sometime just before dawn. Therefore a min and max temp for the day will suffice for 99% of users.
                    A Former User
                      BenGregg02 @Guest
                      @hango Hi, How do i change it to 12hr time instead of 24hr time?
                        A Former User
                          BenGregg01 @Guest
                          @hango thank you so much :)
                          • L Offline
                            lost
                              A Former User
