    News ticker module
    11 Posts 3 Posters 6.6k Views 3 Watching
      Chrisflex
      Looking for a News Ticker module with local and international rss streams
      Please send me a link if you have such a module.
      Scrolling would be an added bonus.
      • BKeyportB Offline
        BKeyport Module Developer
        https://github.com/justjim1220/MMM-NewsFeedTicker
        add your own RSS feeds for whatever you want - google the name of the news source plus “rss” for their RSS feed.
          Chrisflex
          thank you very much I will check it out.
            Chrisflex
            Got it up and running thank you very much.
            Also changed the background to none as per the readme file.
            Only problem now is getting it run a little faster.
            • BKeyportB Offline
              Check the module announcement here in the forums, I seem to recall speed was one of the things talked about.
                Chrisflex @BKeyport
                @BKeyport Thank you I will
                • edwardssjE Offline
                  edwardssj
                  Can I send the code over to you as I cannot get mine to work and breaks the config file
                  C BKeyportB 2 Replies Last reply Reply Quote 0
                    Chrisflex @edwardssj
                    @edwardssj said in News ticker module:
                    Great thanks, just drop in Google Drive if that is ok with you.
                    • BKeyportB Offline
                      BKeyport Module Developer @edwardssj
                      @edwardssj good place to start with the config file breaking is the command
                      npm run config:check
                      in the magicmirror directory. It’ll tell you what you broke.
                        Chrisflex
                        Thanks I do that except when I get to the error I am not sure how to fix it.
