Unsolved Microsoft To-Do (wunderlist replacement?)
i followed the README.MD on github step by step and now i got it running :) i tried a few weeks ago several times without success and was pretty close to give up.
thanks an kind regards!
@geoffroff
I had the same problem and I also had a shorter ID than the example. And of course, the status stay on “Loading tasks” for ever.
Finally, to solve this and get the full length link, I’ve done the following :- create a share link from the list and open it
- click on “Sign in to join list”
- on next windows, click on “open”
I finally have an error “List not found” but in the url is the correct ID which is working as ListID, e.g :
https://to-do.live.com/tasks/AQMkADAwATMwNAItYmQyZS0wNnYxLTAwAi0wMAoALgAAAwyBXwAxHLZDhD1s2yT7wLoBAIZRCieiy1tMpuO70ZBr_R8AA3lr_WoAAAA=
Hope it helps,
Cheers, -
HI on the refresh token I have this error
curl: (6) Could not resolve host:
{“error”:“invalid_request”,“error_description”:“AADSTS900144: The request body must contain the following parameter: ‘grant_type’.\r\nTrace ID: c89030f5-7596-4716-b56b-baafdc670100\r\nCorrelation ID: 3c6c0d5a-8928-47f9-8916-30fb1a369a8e\r\nTimestamp: 2020-04-24 23:29:45Z”,“error_codes”:[900144],“timestamp”:“2020-04-24 23:29:45Z”,“trace_id”:“c89030f5-7596-4716-b56b-baafdc670100”,“correlation_id”:“3c6c0d5a-8928-47f9-8916-30fb1a369a8e”,“error_uri”:“https://login.microsoftonline.com/error?code=900144”}curl: (6) Could not resolve host:
curl: (6) Could not resolve host: application
‘client_id’ is not recognized as an internal or external command,
operable program or batch file.
‘scope’ is not recognized as an internal or external command,
‘redirect_uri’ is not recognized as an internal or external command,
‘client_secret’ is not recognized as an internal or external command,
operable program or batch file. -
@wazzu Excellent worked a treat… ToDo didn’t like the link (List not Found) but when it returned to screen the list had the long ID. I amended the config file and worked like a charm… Thanks G
@andyyy The call seems to be missing some parameters, please check the full command line from https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD, thanks!
@zolabus It seems you faced the same issue as in https://github.com/thobach/MMM-MicrosoftToDo/issues/18. I updated the instructions in https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD#refresh-token-generation-refresh-token to be more Windows friendly, e.g. all in a single line and using double quotes. Could you please try it again with the updated instructions? Thanks!
@thobach: Do you have recommendations to get the due date to show? I have tried to add
element.dueDateTime.dateTime
in the MMM-MicrosoftToDo.js like I have in the past, but now the module won’t show with that that. And no matter how I try to format it withmoment
it still doesn’t like it. I tried it with the simpleelement.id
to see if that would show and it does show the todo ID. Thoughts? I know I am missing something simple. Thanks! -
@smoysauce if your element does not have a dueDateTime (null) this could lead to an error (cannot get property of undefined).
Maybe something like this?
if (element.dueDateTime) { var dueDate = moment(element.dueDateTime.dateTime).format("LL"); }
@lavolp3 Oh good call-out! I tried your example as well as a few other tweaks but it doesn’t seem to like it when I add that snippet in. I don’t know why it’s being so weird. I’ll keep toying around with it, but any other thoughts would be appreciated!
@lavolp3 said in Microsoft To-Do (wunderlist replacement?):
var dueDate = moment(element.dueDateTime.dateTime).format(“LL”);
}So after some tinkering, I figured out that the node.js was not pulling in the due date so I removed the ‘select’ filter so the call URL has
'/tasks?$top='
After that, I was able to add
moment(new Date(element.dueDateTime.dateTime)).format("ddd MMM DD")
to the output string and got the date to show. But for the life of me, I cannot get thevar
orif
statements to work. If I try to use either the module doesn’t load. I have tried them in all different spots and it just doesn’t like it.
