    MMM-Face-Reco-DNN - All new Face Recognition
    36 Posts 14 Posters 25.2k Views 17 Watching
    • nischiN
      nischi @ChrizZz
      @ChrizZz
      Yes i know this issue. i’m currently working on a bugfix. will tell you if i’m done.
      Reply Quote 2
      • I
        Ivanov_d
        I am turning on the monitor using a PIR sensor and it is instant. Keep in mind that it also depends on your monitor, some are slower to respond - this is my second monitor, the first one was very slow to respond to any HDMI related commands.
          ChrizZz
          I have a new strange error and I think it’s just if I restart mm with “pm2 restart mm”. If I reboot my pi, everything is fine.
          SyntaxError: Unexpected token m in JSON at position 0
              at JSON.parse (<anonymous>:null:null)
              at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:375:21)
              at /home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:326:42
              at Array.forEach (<anonymous>:null:null)
              at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:322:15)
              at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:306:21)
              at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:109:22)
              at Socket.emit (events.js:182:13)
              at addChunk (_stream_readable.js:279:12)
              at readableAddChunk (_stream_readable.js:260:13)
              at Socket.Readable.push (_stream_readable.js:219:10)
              at Pipe.onread (net.js:636:20)
          SyntaxError: Unexpected token T in JSON at position 0
          { Error: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
          mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x631b2f0 (ENOSPC)
          mmal: mmal_connection_enable: output port couldn't be enabled
            File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 56, in <module>
              vs = VideoStream(usePiCamera=True).start()
            File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 18, in __init__
              framerate=framerate)
            File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/picam.py", line 10, in __init__
              self.camera = PiCamera()
            File "/usr/lib/python3/dist-packages/picamera/camera.py", line 433, in __init__
              self._init_preview()
            File "/usr/lib/python3/dist-packages/picamera/camera.py", line 513, in _init_preview
              self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
            File "/usr/lib/python3/dist-packages/picamera/renderers.py", line 558, in __init__
              self.renderer.inputs[0].connect(source).enable()
            File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2212, in enable
              prefix="Failed to enable connection")
            File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
              raise PiCameraMMALError(status, prefix)
          picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
              at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:268:21)
              at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:139:32)
              at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:131:13)
              at ChildProcess.emit (events.js:182:13)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
            executable: 'python3',
            options: null,
            script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
            args:
             [ '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
               '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
               '--usePiCamera=1',
               '--method=dnn',
               '--detectionMethod=hog',
               '--interval=2000',
               '--output=0' ],
            exitCode: 1 }
            Blauenfeldt
            I get this too, when my PI can’t connect to the camera. I know that, because if i use
            I will get an error there too. A reboot seems to fix it though. I don’t know what makes it happen, but i suspect the cable.
              sdetweil @Blauenfeldt
              @Blauenfeldt the python code returns an error, but the module does not expect it, and fails.
                rjlinden
                Will this work if the camera is rotated? If not, can you tell me where I need to change the code?
                • H
                  hANNEsLUL
                  when im trying to install the face_recogtnition I’m getting this error code:
                  Does anybody know how to fix this/what is causing this?
                  Sorry if it’s obvious, im a super noob with this kind of stuff
                  Cheers
                  pi@raspberrypi:~ $ pip install face_recognition
                  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                  Collecting face_recognition
                    Using cached https://files.pythonhosted.org/packages/1e/95/f6c9330f54ab07bfa032bf3715c12455a381083125d8880c43cbe76bb3d0/face_recognition-1.3.0-py2.py3-none-any.whl
                  Requirement already satisfied: dlib>=19.7 in ./.local/lib/python2.7/site-packages (from face_recognition) (19.19.0)
                  Collecting face-recognition-models>=0.3.0 (from face_recognition)
                    Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6MB)
                      99% |████████████████████████████████| 100.6MB 1.7MB/s eta 0:00:01
                  Exception:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
                      status = self.run(options, args)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
                      resolver.resolve(requirement_set)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
                      self._resolve_one(requirement_set, req)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
                      abstract_dist = self._get_abstract_dist_for(req_to_install)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
                      self.require_hashes
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 283, in prepare_linked_requirement
                      progress_bar=self.progress_bar
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 836, in unpack_url
                      progress_bar=progress_bar
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 673, in unpack_http_url
                      progress_bar)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 897, in _download_http_url
                      _download_url(resp, link, content_file, hashes, progress_bar)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 617, in _download_url
                      hashes.check_against_chunks(downloaded_chunks)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/hashes.py", line 48, in check_against_chunks
                      for chunk in chunks:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 585, in written_chunks
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/ui.py", line 159, in iter
                      for x in it:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 574, in resp_read
                      decode_content=False):
                    File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 494, in stream
                      data = self.read(amt=amt, decode_content=decode_content)
                    File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 442, in read
                      data = self._fp.read(amt)
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
                      self._close()
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
                      self.__callback(self.__buf.getvalue())
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
                      self.serializer.dumps(request, response, body=body),
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
                      ).encode("utf8"),
                  MemoryError
                  G 1 Reply Last reply
                  • G
                    gaudouy @hANNEsLUL
                    @hANNEsLUL
                    Try this :
                    pip --no-cache-dir install face_recognition
                    -python setup.py install
                    H 1 Reply Last reply
                    • G
                      gaudouy
                      What is the best camera for this module ?
                      Pi NoIR Camera V2
                      alt text
                      https://www.raspberrypi.org/products/pi-noir-camera-v2/
                      Or
                      Camera Module V2
                      alt text
                      https://www.raspberrypi.org/products/camera-module-v2/
                      Thanks for advance :)
                      • H
                        hANNEsLUL @gaudouy
                        @gaudouy
                        Thank you, seems like that worked.
                        But now I am getting following error when I’m trying to run “encode.py”
                        Python 3.7.3 (/usr/bin/python3)
                        >>> %Run encode.py
                          File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/encode.py", line 5, in <module>
                            from imutils import paths
                        ModuleNotFoundError: No module named 'imutils'
                        But when I’m installing “imutils” using “pip install imutils” I am getting no error, but following message:
                        Requirement already satisfied: imutils in ./.local/lib/python2.7/site-packages (0.5.3)
                        Any Idea how to fix that?
                        And to your best camera question for this module, I’m using the PiCamera Module v.2, but I can’t tell you how good its working, since the Face-Reco is not working yet…
                          boppersnr @nischi
                          @nischi
                          First off, I love your module. Well done. Its lots of fun.
                          Question - How can I display the frame/view of the camera on the magic mirror?
                          I would like to see what the camera sees on the screen in Magic Mirror. So I can see the display and the little green boxes with the names of the faces it recognises. Do you know what I would need to do to display the camera frame with the facial recognition code running the scans/outputs on screen?
                          A nischiN 2 Replies Last reply
                          • G
                            ghiesseldorf @nischi
                            @nischi If a user who isn’t known by Face-Reco-DNN moves in front of the camera, is a notification message generated and picked up by MMM-MotionControl? It doesn’t look like the “default” and/or “everyone” classes toggles the screen to un-blank. I was expecting that ANY motion (changes in the capture frames from the camera) would un-blank, but I’m not seeing this behavior. No log-in message gets written to the log.
                            • A
                              Alphons @boppersnr
                              @boppersnr i also want to know.
                              • nischiN
                                nischi @boppersnr
                                @boppersnr said in MMM-Face-Reco-DNN - All new Face Recognition:
                                This feature is not implemented, sorry. Maybe create a ticket in github?
                                  Mattheww
                                  @nischi In my case classes doesn’t work. I was testing this at a bunch of different modules and always was the same resault, nothing change if classes was defined or not. The face recognition is working I tested it with python. But in modules MMM-Face-Reno-DNN I can’t run classes. Whats more I need to run or where I need to look for a trouble and what can I do to solve it.
                                  • A
                                    Aquamannno @nischi
                                    @nischi when I bring this up only a black screen appears with me listing my name but what about the rest of the modules in the magic mirror could be nice with a photo of the recognized precision I find only this (jimbydude / MMM-Face-Multi -User-Recognition-SMAI)
                                    is picked up by magic mirror without error and stops you who are so incredibly good please come up with a variant with photo and welcome greetings.looking forward to the changes. and on whore 1000 thanks.
                                    Sincerely an unlearned raspberry pi owns rpi4 8g hq camera.
                                    Roy Bråthe Norwar
