    Unable to update modules
    20 Posts 3 Posters 7.4k Views 3 Watching
    • K
      KumarTRD @sdetweil
      @sdetweil I’ve tired to run rm package-lock.json but tells me there is no active directory.
        sdetweil @KumarTRD
        @KumarTRD you are in the module folder, right?
        cd  ~/MagicMirror/modules/MMM-Todoist
          this file is rebuilt each time by npm install
          but it is also included in the git repo for this module, it should not be
          • K
            KumarTRD @sdetweil
            @sdetweil correct Sam but do I run the rm package-lock.json in the module folder or in cd /MagicMirror folder? I haven’t tried it in the module folder
              sdetweil @KumarTRD
              @KumarTRD said in Unable to update modules:
              in the module folder, thats where you were when u got the error
              • K
                KumarTRD @sdetweil
                @sdetweil it looks like it’s present in all my modules because I get the same error when attempting to up those as well and my MagicMirror software as well. Any way to complete remove it ?
                  sdetweil @KumarTRD
                  @KumarTRD every module that has a package.json file and uses the step npm install will have a lock file.
                  but as I said, it should NOT have been included in the git package, because it produces this error, and prevents users from moving forward
                  • K
                    KumarTRD @sdetweil
                    @sdetweil ok I’ll give it a try thanks for your assistance.
                    • K
                      KumarTRD @sdetweil
                      @sdetweil any way to remove it manually?
                        sdetweil @KumarTRD
                        @KumarTRD to update MagicMirror itself, use my update script
                        see here
                        its a 2 step process… run once to understand what is going on and things u might have to do, run second time to DO the update
                          sdetweil @KumarTRD
                          yes, the rm command
                          • K
                            KumarTRD @sdetweil
                            @sdetweil thanks for the script I’ll save it for later use and it worked thanks!!
                              rmcon
                              Resurrecting an old thread. Still fairly new to this stuff and trying to learn how to solve problems others have had before…
                              I’ve got notifications that several modules need to be updated and I’m trying to get them done. Currently attempting to update MMM-Remote-Control using the instructions provided :
                              cd ~/MagicMirror/modules/MMM-Remote-Control # adapt directory if you are using a different one
                              git pull
                              npm install # install (new) dependencies
                              I am getting the same messages as the OP. I am in the module folder and tried running the rm command and I get this:
                              ~/MagicMirror/modules/MMM-Remote-Control $ rm package-lock.json
                              rm: cannot remove ‘package-lock.json’: No such file or directory
                              I thought maybe that meant that I had deleted the package-lock and tried running the update command again, but keep getting the same message.
                              I tried running the install script again, and when asked if I wanted to update (Y), I ended up with the same problem.
                              Appreciate any guidance. Running MM v2.30.0 (installed using Sam’s scripts) on RPI 3B+.
                                sdetweil @rmcon
                                @rmcon post results of
                                git status
                                in the mmm-remote-control
                                folder
                                  rmcon @sdetweil
                                  ~/MagicMirror/modules/MMM-Remote-Control $ git status
                                  On branch master
                                  Your branch is behind ‘origin/master’ by 8 commits, and can be fast-forwarded.
                                  (use “git pull” to update your local branch)
                                  (use “git add/rm …” to update what will be committed)
                                  (use “git restore …” to discard changes in working directory)
                                  modified: modules.json
                                  deleted: package-lock.json
                                  modified: package.json
                                  no changes added to commit (use “git add” and/or “git commit -a”)
                                    sdetweil @rmcon
                                    @rmcon ok the quick way
                                    git reset --hard HEAD
                                    then
                                    git pull
                                    Then
                                    npm install
                                      rmcon @sdetweil
                                      That worked! No idea what we just did, but the update went through and MM worked fine after reboot, to include the module,
                                      Sam, you’re a wizard as far as I’m concerned. Thanks for taking the time to assist us less savvy folks.
                                        sdetweil @rmcon
                                        @rmcon thanks, but no wizardry
                                        a little info
                                        we use a source code repository, that keeps track of every file change, add, delete, rename, whatever.
                                        on linux there is no hidden file attribute, like on Windows… but by convention, if a file or folder starts with a dot(.) then it is not shown unless explicitly requested
                                        git is the source code repository we all use (MM and the modules)
                                        it is called a distributed scm (source code mgmt) system, because whenever you have some of a repo, you have ALL of it from its start to now…
                                        you git clone to make a local copy (linked to the source of the clone)
                                        on linux that is stored in the .git folder (notice the .)
                                        it knows about every little change to any of the files… oh
                                        when you see them, that is called the ‘working copy’… may match the repo, might not
                                        so, we asked git, tell me the status of the working copy as compared to the repository (in the .git folder)
                                        and it said some file hadchanged and some file had been deleted.
                                        neither of those files (package.json or package-lock.json) affect the actual running of the module, they are part of the housekeeping, setup, installation…
                                        now, you said you were going to UPDATE cause the module had changed,
                                        so you don’t NEED those files as they exist(or don’t) , cause you are going to PULL a NEW copy of the repo to your system (repo and working copy)
                                        git provides commands to do lots of things,
                                        you can look thru the history of the repo, with git log and git history
                                        an important idea, is a pointer to the top of the last incorporated (committed) changes
                                        that term is called HEAD, the HEAD of the change tree…
                                        so, we asked git, please restore our working copy (and any potential additions (commits) to the repo BACK to the HEAD position
                                        AND reset all the working copy files too…
                                        –hard means and working copy
                                        ok, so NOW we have the working copy matching the repo state of the clone you did
                                        now lets ask to refresh the local repo with the repo copy that has changed
                                        that action is PULL the repo to us, and resynch
                                        (it doesn’t like it when the working copy doesn’t match its expectations, so we ‘forced’ it back to HEAD)
                                        now the PULL updates the repo, AND the working copy… phew… and it updated the two files it was unsure about before
                                        but who knows what the impact of the change are (the module author, did we look at any comments he might have made (no… not me!)…)
                                        so, lets just redo the node package managers view of the system
                                        npm install will recheck any locally added libraries (in node_modules folder)
                                        and do any pre/post install tasks defined in the package.json
                                        NOW we are file level up to date with the latest official repo
                                        AND we are runtime up to date
