    Unable to update modules
    20 Posts 3 Posters 4.8k Views 3 Watching
      this file is rebuilt each time by npm install
      but it is also included in the git repo for this module, it should not be
      • K Offline
        KumarTRD @sdetweil
        @sdetweil correct Sam but do I run the rm package-lock.json in the module folder or in cd /MagicMirror folder? I haven’t tried it in the module folder
          sdetweil @KumarTRD
          @KumarTRD said in Unable to update modules:
          in the module folder, thats where you were when u got the error
          • K Offline
            KumarTRD @sdetweil
            @sdetweil it looks like it’s present in all my modules because I get the same error when attempting to up those as well and my MagicMirror software as well. Any way to complete remove it ?
              sdetweil @KumarTRD
              @KumarTRD every module that has a package.json file and uses the step npm install will have a lock file.
              but as I said, it should NOT have been included in the git package, because it produces this error, and prevents users from moving forward
              • K Offline
                KumarTRD @sdetweil
                @sdetweil ok I’ll give it a try thanks for your assistance.
                • K Offline
                  KumarTRD @sdetweil
                  @sdetweil any way to remove it manually?
                    sdetweil @KumarTRD
                    @KumarTRD to update MagicMirror itself, use my update script
                    see here
                    its a 2 step process… run once to understand what is going on and things u might have to do, run second time to DO the update
                      sdetweil @KumarTRD
                      yes, the rm command
                      • K Offline
                        KumarTRD @sdetweil
                        @sdetweil thanks for the script I’ll save it for later use and it worked thanks!!
