    Unable to update modules
    20 Posts 3 Posters 4.8k Views 3 Watching
    • K Offline
      KumarTRD @sdetweil
      @sdetweil I’ve tired to run rm package-lock.json but tells me there is no active directory.
        sdetweil @KumarTRD
        @KumarTRD you are in the module folder, right?
        cd  ~/MagicMirror/modules/MMM-Todoist
          this file is rebuilt each time by npm install
          but it is also included in the git repo for this module, it should not be
          • K Offline
            KumarTRD @sdetweil
            @sdetweil correct Sam but do I run the rm package-lock.json in the module folder or in cd /MagicMirror folder? I haven’t tried it in the module folder
              sdetweil @KumarTRD
              @KumarTRD said in Unable to update modules:
              in the module folder, thats where you were when u got the error
              • K Offline
                KumarTRD @sdetweil
                @sdetweil it looks like it’s present in all my modules because I get the same error when attempting to up those as well and my MagicMirror software as well. Any way to complete remove it ?
                  sdetweil @KumarTRD
                  @KumarTRD every module that has a package.json file and uses the step npm install will have a lock file.
                  but as I said, it should NOT have been included in the git package, because it produces this error, and prevents users from moving forward
                  • K Offline
                    KumarTRD @sdetweil
                    @sdetweil ok I’ll give it a try thanks for your assistance.
                    • K Offline
                      KumarTRD @sdetweil
                      @sdetweil any way to remove it manually?
                        sdetweil @KumarTRD
                        @KumarTRD to update MagicMirror itself, use my update script
                        see here
                        its a 2 step process… run once to understand what is going on and things u might have to do, run second time to DO the update
