    Unable to update modules
    20 Posts 3 Posters 5.0k Views 3 Watching
    • K Offline
      KumarTRD
      When attempting to update my magic mirror modules I get the following error messgae
      “pi@raspberrypi:~/MagicMirror/modules/MMM-Todoist $ git pull
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting”
      1)How do i solve this?
      2) What caused this “package-lock.json”?
      3) Anyway to remove this package permanently?
        @KumarTRD said in Unable to update modules:
        package-lock.json
        erase the package-lock.json and then git pull again, and npm install
        • K Offline
          KumarTRD @sdetweil
          @sdetweil I’ve tired to run rm package-lock.json but tells me there is no active directory.
            sdetweil @KumarTRD
            @KumarTRD you are in the module folder, right?
            cd  ~/MagicMirror/modules/MMM-Todoist
              this file is rebuilt each time by npm install
              but it is also included in the git repo for this module, it should not be
              • K Offline
                KumarTRD @sdetweil
                @sdetweil correct Sam but do I run the rm package-lock.json in the module folder or in cd /MagicMirror folder? I haven’t tried it in the module folder
                  sdetweil @KumarTRD
                  in the module folder, thats where you were when u got the error
                  • K Offline
                    KumarTRD @sdetweil
                    @sdetweil it looks like it’s present in all my modules because I get the same error when attempting to up those as well and my MagicMirror software as well. Any way to complete remove it ?
                      sdetweil @KumarTRD
                      @KumarTRD every module that has a package.json file and uses the step npm install will have a lock file.
                      but as I said, it should NOT have been included in the git package, because it produces this error, and prevents users from moving forward
                      • K Offline
                        KumarTRD @sdetweil
                        @sdetweil ok I’ll give it a try thanks for your assistance.
