Unable to update modules
20 Posts 3 Posters 2.8k Views 3 Watching
  • K Offline
    KumarTRD
    When attempting to update my magic mirror modules I get the following error messgae
    “pi@raspberrypi:~/MagicMirror/modules/MMM-Todoist $ git pull
    error: Your local changes to the following files would be overwritten by merge:
    package-lock.json
    Please commit your changes or stash them before you merge.
    Aborting”
    1)How do i solve this?
    2) What caused this “package-lock.json”?
    3) Anyway to remove this package permanently?
    • S Away
      @KumarTRD said in Unable to update modules:
      package-lock.json
      erase the package-lock.json and then git pull again, and npm install
      K 1 Reply Last reply May 11, 2020, 3:30 AM Reply Quote 0
      • K Offline
        KumarTRD @sdetweil
        @sdetweil I’ve tired to run rm package-lock.json but tells me there is no active directory.
        S 1 Reply Last reply May 11, 2020, 3:31 AM Reply Quote 0
        • S Away
          sdetweil @KumarTRD
          @KumarTRD you are in the module folder, right?
          cd  ~/MagicMirror/modules/MMM-Todoist
          K 1 Reply Last reply May 11, 2020, 3:33 AM Reply Quote 0
          • S Away
            this file is rebuilt each time by npm install
            but it is also included in the git repo for this module, it should not be
            K 1 Reply Last reply May 11, 2020, 3:35 AM Reply Quote 0
            • K Offline
              KumarTRD @sdetweil
              @sdetweil correct Sam but do I run the rm package-lock.json in the module folder or in cd /MagicMirror folder? I haven’t tried it in the module folder
              S 1 Reply Last reply May 11, 2020, 3:33 AM Reply Quote 0
              • S Away
                sdetweil @KumarTRD
                in the module folder, thats where you were when u got the error
                K 1 Reply Last reply May 11, 2020, 3:39 AM Reply Quote 0
                • K Offline
                  KumarTRD @sdetweil
                  @sdetweil it looks like it’s present in all my modules because I get the same error when attempting to up those as well and my MagicMirror software as well. Any way to complete remove it ?
                  S 2 Replies Last reply May 11, 2020, 3:36 AM Reply Quote 0
                  • S Away
                    sdetweil @KumarTRD
                    @KumarTRD every module that has a package.json file and uses the step npm install will have a lock file.
                    but as I said, it should NOT have been included in the git package, because it produces this error, and prevents users from moving forward
                    K 1 Reply Last reply May 11, 2020, 3:41 AM Reply Quote 0
                    • K Offline
                      KumarTRD @sdetweil
                      @sdetweil ok I’ll give it a try thanks for your assistance.
