    Modules not showing up on KWEB or Midori
    7 Posts 2 Posters 5.3k Views 2 Watching
    • N Offline
      nixidee
      i have a small problem with the modules. When i try to load MagicMirror² in a Browser on my Pi Zero from console, some modules won’t load. Instead of the module it shows a text like :“module_3_MMM-Fuel” or " module_4_MMM-soccer".
      If i load it from desktop or another computer everything works fine.
      this is the way i load the Browser (sudo xinit script.sh):
      Midori:
      #!/bin/sh
      xset -dpms # disable DPMS (Energy Star) features.
      xset s off # disable screen saver
      xset s noblank # don't blank the video device
      unclutter &
      matchbox-window-manager &
      midori -e Fullscreen -a http://localhost:8080
      KWeb:
      #!/bin/sh
      unclutter &
      kweb -KJERLH http://localhost:8080
      Can anybody help me please?
      Thank you.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @nixidee
        @nixidee both mentioned modules are created by me. A guess in the dark would be that the browsers probably don’t support the new ECMA SCRIPT 6 features that I’m using there, can you post a screenshot of the browser console?
        • N Offline
          nixidee
          Do you mean this?
          That is this line:
          setInterval(() => {
          Or what did you need exactly?
          What (Kiosk)Browser do you use?
            @nixidee yes that’s what I was talking about.
            The following lines should get you going, but the ecmascript is finalized and standard since june last year, you should probably think about switching the browser if their updates are that far behind
            MMM-soccer
            var self = this;
            setInterval(function(){
                        self.getData();
            }, this.config.api_key ? 300000 : 1800000);
            MMM-Fuel
            var self = this;
            return setInterval(function(){
                        self.sortByPrice = !self.sortByPrice;
                        self.updateDom(300);
            }, this.config.rotateInterval);
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              nixidee @strawberry 3.141
              @strawberry-3.141
              Thanks for your work. Which Browser do you recomment? Both are lightweight kiosk Browsers and the pi zero needs a lightweight browser as far as I know.
              I gues, I have to clone it again and npm install it again?
                @nixidee you can either do some research yourself which pi Zero browser can handle es6/ecmascript2015 features, I’m using the Same browser electron is based on (chromium) or you have to do the changes manually
                • N Offline
                  @strawberry-3.141
                  Well i tried Chromium but i didn’t get it to work on the Pi Zero. With the code you provided it works well. Thank you for your time.
