    IR Overlay - pulling hair out !
    5 Posts 4 Posters 1.6k Views 3 Watching
    • E Offline
      emailuser
      Hi everyone … i have built my MM frame and am using a old 32"LCD TV , sitting on top i have a 32" IR Touch overlay … but the overlay responds to touch in landscape mode - i have a pi4 and have rotated the TV screen using DISPLAY=:0 xrandr --output HDMI-1 --rotate left , but despite looking at loads of forums / websites nothing seems to work to make the touch overlay rotate as well … my overlay is Bus 001 Device 003: ID 1ff7:0013 CVT Electronics.Co.,Ltd CVTouch Screen (HID)
      Any help greatly appreciated !!!
        sdetweil @emailuser
        @emailuser well, here is a concise description of how to do it with a pi screen and overlay…
        https://www.circuitbasics.com/raspberry-pi-touchscreen-calibration-screen-rotation/
        two different configs…
        • E Offline
          emailuser
          @emailuser said in IR Overlay - pulling hair out !:
          Thanks Sam … but those instructions are for a touchscreen – i have an IR USB overlay which enables touch on the screen ,
          as an example on the instruction
          Enter sudo nano /etc/modules at the command prompt to edit the file. Go to the line for the ads7846_device parameters and move the cursor to the right to find it: - i dont have that in that file
          • F Offline
            fordi
            I’m having the same issues, the touch overlay works perfectly in landscape mode but my mirror is designed to be in portrait mode.
            If i find a solution i will post on here. I have contacted manufacturers to see if they can help also.
            • SnilleS Offline
              Snille Module Developer
              Hi, I had the same issue when I built my mirror… Here is how I solved it. Made a .sh script with all the information: :)
              #!/bin/bash
              # Before I just tested with the xinput command directly in the autostart file, but that did not work. So now instead I just created a script called xin.sh.
              # nano ~/xin.sh
              # Then added
              # DISPLAY=:0.0 xinput --set-prop "Multi touch Multi touch overlay device" "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
              # There should actually be 3 spaces between “Multi touch” and “Multi touch overlay device”. For some reason the board removes the extra spaces here.
              # You can actually find the “name” of the device with this command form a console: DISPLAY=:0.0 xinput list
              # Shows something like this:
              # Virtual core pointer id=2 [master pointer (3)]
              #   Virtual core XTEST pointer id=4 [slave pointer (2)]
              #   Multi touch Multi touch overlay device id=6 [slave pointer (2)]
              # Virtual core keyboard id=3 [master keyboard (2)]
              # Virtual core XTEST keyboard id=5 [slave keyboard (3)]
              # Depending on what you have connected to your RPi. 🙂
              # So, after creating the xin.sh I added that to the autostart file for LXDE:
              # Like this:
              # nano ~/.config/lxsession/LXDE-pi/autostart
              # Added at the end of the file.
              # @/home/pi/xin.sh
              # Restarted and it works.
              Maybe you guys can use it some how? :)
              If you cant find it, make it and share it!
              Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
