    Config Error
    newcodeerror
    39 Posts 5 Posters 17.7k Views 5 Watching
      PHAGE.GOV @sdetweil
      @sdetweil wait so it said the options were “string” and “false” for “welcome message” thats where its wrong, so i think its fixed?? ill update if it isnt fixed lol
        sdetweil @PHAGE.GOV
        @PHAGE-GOV said in Config Error:
        so does that just mean i should delete that line altogether?
        no idea… maybe it is an important line,
        but as I said, the error is reported on the line after the actual problem
        if u read the linked getting started
        you would see that elements in config.js are
            sometext : somevalue
        where somevalue MUST be quoted before and after (single or double doesn’t matter, as long as both ends are the same)
        unless somevalue is true/false, or a number
        AND you need to add a continuation char (comma ,) at the end to the line if the next line
        is include in this info, or more info is comming (another module config for example)
        P 1 Reply Last reply
          PHAGE.GOV @sdetweil
          @sdetweil yeah ill try that, i tried fixing “string” because it had an extra space in it but i got the no config.js file again, i will try looking for the other stuff rn
          S lavolp3L 2 Replies Last reply
            sdetweil @PHAGE.GOV
            if it has an error in the config, it throws up its hands and says no config…
            yes there is one, but he can’t tell what to do
            • lavolp3L
              lavolp3 Module Developer @PHAGE.GOV
              @PHAGE-GOV I guess you have that part in the alert module.
              It needs to be like @sdetweil said. on the left side a single word, here welcome_message. You need to take care of underlines and the upper-/lowercase.
              Then there is a : and then the value which can be a string or false.
              welcome_message: 'Any string you like'
              OR
              welcome_message: false
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
                sdetweil @lavolp3
                @lavolp3 but his error was
                Unexpected token Welcome_message
                so, one at least more this is wrong
                lavolp3L 1 Reply Last reply
                • lavolp3L
                  @sdetweil Looking at above post, there’s looots of errors in the config.
                  @PHAGE-GOV we can’t lead you through all of these.
                  You need to understand how config.js needs to look. Only one comma set false or forgotten breaks the whole file and the mirror.
                  • lavolp3L
                    lavolp3 Module Developer @lavolp3
                    @lavolp3 The alert part needs to look like this:
                    			module: "alert",
                    			position: "right",
                    			welcome_message: "a string"
                      PHAGE.GOV @sdetweil
                      @sdetweil okay so ive been combing through the code, and since i didnt know how to properly edit .json files, i had alot of cleanup to do, im still not done, but getting there. what is a trailing space though? i dont know what to remove
                        PHAGE.GOV @lavolp3
                        @lavolp3
                        			module: "compliments",
                        			position: "lower_third",
                        			compliments: {
                        				"anytime" : [
                        					"Hey there sexy!"
                        				"morning" : [
                        so 64 is the compliments line and it says it has trailing spaces. Im actually learning so much about json files rn so thank you @sdetweil and @lavolp3
                          sdetweil @PHAGE.GOV
                          @PHAGE-GOV ignore the trailing space error. It’s stupid
                            PHAGE.GOV @sdetweil
                            @sdetweil indeed it is, i found it tho, and i fixed everything else too! thank you so much! and i learned so much from this also, i feel much more confident poking around and i defs learned much more about proper coding
                              sdetweil @PHAGE.GOV
                              @PHAGE-GOV and finding your way on the next error. After 3 years I still make them
                                PHAGE.GOV @sdetweil
                                @sdetweil yeah, but npm run config:check was such a life saver
                                • BKeyportB
                                  BKeyport Module Developer
                                  one of the biggest tips I can give you is to throw out everything you know about capitalization…
                                  Welcome_message is different from welcome_message
                                  Most of the time, with RARE exception, the initial letter is lowercase. javacriptIsWeird
                                    sdetweil @BKeyport
                                    @BKeyport no… it is entirely up to the author of the module what case is used.
                                    there are no rules…
                                    only thing is javascript is case sensitive
                                    var foo
                                    is different than
                                    var fOo
                                    etc…
                                    the config code doesn’t care, it takes all the settings and makes an object
                                    the module then looks for specific items… almost NEVER checking for case mismatch
                                    config.foo
                                    will NOT find
                                    config.fOo
                                    it is NOT an error to config if fOo is not present.
                                    filenames on linux are also case sensitive
                                    BKeyportB 1 Reply Last reply
                                    • BKeyportB
                                      @sdetweil That’s effectively what I said… I’m working from within the naming conventions typically used by module authors, including myself, and trying to stress that case is important, because if you come from a world where it’s not (DOS/Windows, perhaps?) it takes some getting used to.
                                      bottom line, Welcome_message is not the same as welcome_message
                                        sdetweil @BKeyport
                                        @BKeyport said in Config Error:
                                        i didn’t know there were any conventions! least I don’t follow anything written anywhere
                                        evroomE 1 Reply Last reply
                                        • evroomE
                                          evroom @sdetweil
                                          @sdetweil said in Config Error:
                                          Naming conventions are not must, but it is used to make code more readable and understandable.
                                          A quick google came up with this useful page:
                                          https://github.com/ktaranov/naming-convention/blob/master/JavaScript Name and Coding Conventions.md
                                          MagicMirror version: 2.37.0
                                            sdetweil @evroom
                                            @evroom i have been coding for 45 years… i know what they are and know what good ones produce…
                                            however, specific casing has always been a useless conversation…
                                            make names meaningful, use case where appropriate…
                                            i don’t follow camelcase, or any other std.
