    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 79.2k Views 19 Watching
    • michael5rM Offline
      michael5r Module Developer @craig859
      @craig859 said in MMM-Hue-Lights - new module for your Philips Hue lights!:
      Even after using Hue Developer to access the API debug/clip.html and generate a user string the Magic Mirror displays “please add your hue bridge IP and user to MagicMirror config.js file.”
      Has anyone seen anything new on this? Is there a change in the authentication for Hue, maybe something that broke this module?
      There shouldn’t be - the Hue API hasn’t been updated in a long time, and both my mirrors are running just fine with this module.
        michael5r Module Developer @Cain
        @Cain said in MMM-Hue-Lights - new module for your Philips Hue lights!:
        i also found that i had to change folder name from
        MMM-Hue-Lights to mmm-hue-lights - not sure why but i did.
        After the 10mintues when it stops workings. can you then access the debug using the website? Only when the error occurs.
        also have you done the sudo apt-get update && sudo apt-get full-upgrade ?
        The folder should be mmm-hue-lights - it’s case-sensitive, so MMM-Hue-Lights wouldn’t work.
          michael5r Module Developer @jasim
          @jasim said in MMM-Hue-Lights - new module for your Philips Hue lights!:
          I installed mmm-hue-lights by default and get the following error message after 5 minutes. Hue API ERROR: Error: Read ECONNRESET. I ask for help with this problem. I’ve already reinstalled everything and it doesn’t help.
          Have you tried changing the updateInterval setting to be a higher number than the default? I would suggest trying 10 mins - eg. setting it to 600000
            I’ve released a new 1.4.0 version of this module that will hopefully help with the refresh issue - it now automatically reschedules an update, no matter whether there’s an error or not. Thanks to @ulrichwisser for pushing this fix.
            Please download the version and see if that solves your issues.
              jasim
              I updated the module and tested it for several hours. The module fails after 45 - 60 minutes (API ERROR) and no longer works.
              And not only that, the entire mirror no longer works.
              After removing the module from the mirror, the mirror works again.
              michael5rM 1 Reply Last reply Reply Quote 0
                Can you try running your mirror in dev mode and post some logs?
                  jasim @michael5r
                  @michael5r said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                  Would you tell me what to do, I am a layperson and not a professional.
                    Instead of running npm run start in your Magic Mirror folder to start the mirror, try running npm start dev which will open a browser console next to your mirror instance. Then look for any errors (marked in red) in there.
                      jasim
                      npm start dev
                        @jasim You need to be in the folder of your Magic Mirror installation when you run these commands.
                          jasim
                          npm start dev
                            @jasim You already have another instance of Magic Mirror running (that’s the EADDRINUSE error) - you’ll need to stop that before running npm start dev. How do you normally start/stop your mirror?
                              jasim
                              Ich starte den Spiegel automatisch wenn der pi hochfährt.
                              Wie stoppe ich EADDRINUSE Fehler.
                                @jasim Yeah, but you must have set it up at some time - for instance, I use pm2 on my mirrors, so I can do pm2 stop mm to stop my magic mirror instance.
                                  jasim
                                  Was soll ich machen ?
                                    @jasim Sorry, I don’t speak German - can you please post in english?
                                      jasim
                                      Was soll ich machen?
                                      Sorry, what should I do?
                                      • F Offline
                                        fordi @michael5r
                                        @michael5r You have just made my day. After messing about for the best part of a day trying to get the module working, your post has made this module spring to life! I installed via Magic Mirror Package Manager and the folder name had upper and lower case naming. Im going to get a beer now!! lol…
                                        • Feedy88F Offline
                                          Feedy88
                                          Hey guys,
                                          first off, great module @michael5r, thanks a lot. Unfortunately I have issues getting it to work as soon as I use the displayFilter attribute. Using the default works perfectly fine and shows all my lights. As soon as I only have one specific light in the displayFilter-array, I can only see “Loading…” on my mirror. Config looks fine (below) and logs are identical with default and specified.
                                          Side Note: The light I am calling is “Kugel” which is not an original Hue but Ikea Tradfri. Additionally I have other lights called “Kugel 30er” “Kugel 40er” and “Kugel 60er”. Could this be the source of failure?
                                          Works:
                                          Doesn’t work:
                                          Thanks for help in advance.
                                          • N Offline
                                            nick95cookie
                                            I set this up and everything was working wonderfully. I shut down my pi and installed it into my frame with the same screen and now this module is not working but nothing has changed. It loads but I cannot see the module on my MM screen
                                            • 4 / 5
