    Love the idea from first sight, now a bit confused with this issues!
    3 Posts 2 Posters 1.7k Views 2 Watching
    • dracebusD Offline
      dracebus
      Hi there! thank you so much for all of this, its quite amazing!!!
      Had a rough start:
      *bought from TAP plastic a a4 size mirrored acrilic, u$s 40 + u$s 77 shipping+ end up paying also u$s 80 in customs taxes in my country.
      Anyway, back to the issues:
      *Using raspberry pi 3 , installed NOOBs and then did the 1 command line to install MagicMirror.
      Then updated some of the config files as stated.
      *current weather and weatherforecast are with the appid sign display message though I have register to the site and updated with the provided API key.
      locationID: “6693229”,
      Can someone confirm that it works on your end?
      *Calendar:
      I just changed:
      http://www.calendarlabs.com/templates/ical/US-Holidays.ics
      For
      http://www.calendarlabs.com/templates/ical/Argentina-Holidays.ics
      Lastly when I do npm start on the log it says:
      Sockets connected & modules started …
      Whoops! There was an uncaught exception…
      { Error: listen EADDRINUSE :::8080
      at Object.exports._errnoException (util.js:1026:11)
      at exports._exceptionWithHostPort (util.js:1049:20)
      at Server._listen2 (net.js:1253:14)
      at listen (net.js:1289:10)
      at Server.listen (net.js:1385:5)
      at new Server (/home/pi/MagicMirror/js/server.js:17:9)
      at /home/pi/MagicMirror/js/app.js:129:17
      at loadConfig (/home/pi/MagicMirror/js/app.js:42:4)
      at App.start (/home/pi/MagicMirror/js/app.js:115:3)
      at Object. (/home/pi/MagicMirror/js/electron.js:81:6)
      code: ‘EADDRINUSE’,
      errno: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘::’,
      port: 8080 }
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @dracebus
        @dracebus said in Love the idea from first sight, now a bit confused with this issues!:
        something is already using this port. got to the config.js an change the port in there to something else
        dracebusD 1 Reply Last reply Reply Quote 0
        • dracebusD Offline
          dracebus @strawberry 3.141
          @strawberry-3.141 said in Love the idea from first sight, now a bit confused with this issues!:
          yeah there was an instance running.
          Also, not sure how to quit the app, I am really new to terminal usage, I stopped once using NPM stop but I cant get that to work anymore, I type stuff and nothing happens when I hit enter
