    Mirror supplier in Norway?
    28 Posts 8 Posters 27.7k Views 8 Watching
      Stellanova
      Does anyone know where we can get a two way mirror (acrylic) in Norway?
        Phantom @Stellanova
        @Stellanova Jeg ville gått for glass speil siden du ikke kan bruke touch med acryl. Når det gjelder levrandør ville jeg nok sett i england eller andre steder for prisen i norge er over dobbelt av UK.
        C S 2 Replies Last reply Reply Quote 0
          Cato Module Developer @Phantom
          @Phantom Even if the mirror is cheaper in England, what about the freight cost?
          And do really glass work with a touchscreen?
            Phantom @Cato
            @Cato Well yes it would be cheaper to buy the glass from the UK cuz Norwegian suppliers need to pay freight and tax before adding what they want to make on it. This type of glass is not something thay have in stock so they to will have to order, remeber we are making a magic mirror so the glass should be made for this. Smart glass is made to cover tv or a computer screen so the colors dont get distorted.
            Yes touch will work behind glass, there is normaly two ways you do thtis. IR frame wich is cheap and great if you have a frame on the mirror. I always use pcap screens since i can make the mirror bordeless with that. pcap is (Projected Capacitive touch screen) its more expensive but looks great.
              Stellanova @Phantom
              @Phantom Takk for tipset, ja det var veldig dyr hær i Norge. Jeg har ikke tenkt å gå for touch da. Vent så det finnes toveis speil av glass, jeg gikk ut fra at det bare fantes av akryl.
                Phantom @Stellanova
                @Stellanova said in Mirror supplier in Norway?:
                He he, det finnes i glass også som er det beste siden acryl kan vregnge bilde litt. Skal du bare ha tv på badet?
                  dakipro
                  I was planning on buying picture frame with the glass and then try the foil on it. Any tips where the foil could be purchased?
                  I saw that biltema hadde slik folie, but not sure if it is available anymore. Any tips on where to find the foil?
                    AAPS
                    Does anyone know where I could get a cheap mirror in the US?
                      Phantom @dakipro
                      @dakipro Well foile can be used but you have to get a hi D number or else you will not see the screen. You will need to buy from a solar window tint provider for homes. This is the clearest http://www.vindusfolie-nettbutikk.no/shop/product/silver-35-ext-solfilm?tm=solfilm-til-hus
                      Hope this helps
                      C D 2 Replies Last reply Reply Quote 0
                        @Phantom have you tested this? I’m wondering about the reflective properties. Will the reflection be too dark (ie no wife acceptance)…
                          Phantom @Cato
                          @Cato No i have never tested it my self but i have seen it done with great sucess. I my self use costum made mirror glas https://forum.magicmirror.builders/topic/1251/custom-magic-mirror-glas-with-27-touchfoil-and-27-led-screen-for-sale
                            @Phantom The problem, I discovered when I built my mirror, is that it might look OK up until you compare it to a normal mirror. Then you see the reflection is darker.
                              Phantom @Cato
                              @Cato Yes that why i use the costum glas. But i think the film will give very good reflection, you have just two way mirror film to but not in norway.
                                dakipro @Phantom
                                @Phantom takk, I will check it out. I do not see D number in their specs, only B G and U. I read once on those numbers, but I cannot seem to find it now on the forum.
                                • O Offline
                                  OlofL
                                  Anyone got success with the foil from vindusfolie butikken?
                                    dakipro
                                    I decided to try to find actual glass mirror first. Have sent email to 4-5 companies that sell windows and mirrors, still waiting for someone to answer.
                                    I hope that something like this could be used http://www.vgi.no/default.asp?pageid=10651
                                      dakipro
                                      I got few offers from glass and mirror suppliers in Norway from 1900kr to 5000kr for piece of two way mirror (argusspeil/spionspeil) size 60x80cm.
                                      Most offers were around 2000kr (220e) and I am now evaluating is it worth it.
                                      Foil with a simple piece of glass is half the price, but I am really afraid that I will get bubbles with the foil and that foil will be damaged after some time.
                                      I have also found mirrored plexiglass for around 40e, but I am afraid of reflection being skewed and look ugly, and that would irritate me a lot. Maybe to use regular glass behind the plexiglass (just to keep plexiglass straight if possible)
                                      Not sure yet… total price for mirror will be over 350e… still convincing myself (and the spouse :) )
                                        Building the thing is not that difficult. Get the approval is… ;-)
                                        My wife wasn’t that convinced when I built it, But after after a day with no internet connection at home, and hence no updated trip info on my Ruter module, she had to admit it was nice with a magig mirror in the hallway.
                                          Phantom
                                          Hi
                                          From a project i have a costum made mirro glass 710*400mm. The glass is custom 1.8mm temperd magic mirror glass that easly shows the screen behind. I also have non mounted 27" 10 point pcap touch foil for the glass along with a 27" AOC led screen. This is just parts that was ment for a project but the client had me do something else.
                                          Price is 450 dollars
                                            Stellanova
                                            So has anyone got good offers from some spesific companies for a glass mirror?
