    Mirror supplier in Norway?
    28 Posts 8 Posters 26.3k Views 8 Watching
      Phantom @Stellanova
      @Stellanova said in Mirror supplier in Norway?:
      @Phantom Takk for tipset, ja det var veldig dyr hær i Norge. Jeg har ikke tenkt å gå for touch da. Vent så det finnes toveis speil av glass, jeg gikk ut fra at det bare fantes av akryl.
      He he, det finnes i glass også som er det beste siden acryl kan vregnge bilde litt. Skal du bare ha tv på badet?
        dakipro
        I was planning on buying picture frame with the glass and then try the foil on it. Any tips where the foil could be purchased?
        I saw that biltema hadde slik folie, but not sure if it is available anymore. Any tips on where to find the foil?
          AAPS
          Does anyone know where I could get a cheap mirror in the US?
            Phantom @dakipro
            @dakipro Well foile can be used but you have to get a hi D number or else you will not see the screen. You will need to buy from a solar window tint provider for homes. This is the clearest http://www.vindusfolie-nettbutikk.no/shop/product/silver-35-ext-solfilm?tm=solfilm-til-hus
            Hope this helps
            CatoC D 2 Replies Last reply Reply Quote 0
            • CatoC Offline
              Cato Module Developer @Phantom
              @Phantom have you tested this? I’m wondering about the reflective properties. Will the reflection be too dark (ie no wife acceptance)…
                Phantom @Cato
                @Cato No i have never tested it my self but i have seen it done with great sucess. I my self use costum made mirror glas https://forum.magicmirror.builders/topic/1251/custom-magic-mirror-glas-with-27-touchfoil-and-27-led-screen-for-sale
                CatoC 1 Reply Last reply Reply Quote 0
                • CatoC Offline
                  @Phantom The problem, I discovered when I built my mirror, is that it might look OK up until you compare it to a normal mirror. Then you see the reflection is darker.
                    Phantom @Cato
                    @Cato Yes that why i use the costum glas. But i think the film will give very good reflection, you have just two way mirror film to but not in norway.
                      dakipro @Phantom
                      @Phantom takk, I will check it out. I do not see D number in their specs, only B G and U. I read once on those numbers, but I cannot seem to find it now on the forum.
                      • O Offline
                        OlofL
                        Anyone got success with the foil from vindusfolie butikken?
