    Syntax of MMM-NotificationTrigger
    3 Posts 1 Posters 1.7k Views 1 Watching
      MilkShake
      I am having difficulties with the syntax of MMM-NotificationTrigger. I have this syntax working (semi):
      module: "MMM-NotificationTrigger",
              triggers:[
                  trigger: "PLAY_SOUND",
                  fires: [
                      fire:"USER_PRESENCE",
                      payload: function(payload) {
                        return false
                      fire:"SHOW_ALERT",
                        return {
                          type: "notification",
                          title: "Porten",
                          message: "Der er nogen ved porten!"
      I need to add a trigger using webhook for the notification “Open_Gate” that fires a local script. Every time I change the syntax it seems to get broken. Can anyone help?
        MilkShake @MilkShake
        @MilkShake So IFTTT makes a webrequest that looks like this:
        URL: https://MMPUBLICURL/webhook
        Method: POST
        Content type: application/json
        Body: { “sender”: { “name”:“IFTTT” }, “notification”: “OPEN_GATE”}
        I thought I could do something like:
                useWebhook: true,
                triggers:[
                    fires: [
                          return false
                        fire:"SHOW_ALERT",
                          return {
                            title: "Porten",
        			trigger: "OPEN_GATE",
        			fires: [
        				exec: "home/pi/open_gate.py"
        What is the correct syntax to fire a script?
          MilkShake
          @MilkShake Got it to work using:
               useWebhook:true,
          	 triggers:[
          		  fires: [
          			fire: "USER_PRESENCE",
                            return false
          		fires: [
          		   fire: "OPENING_THE_GATE",
          		   exec: "sudo python /home/pi/open_gate.py"
