    Config code not working?
    8 Posts 2 Posters 1.7k Views 1 Watching
    • johnnyboyJ
      johnnyboy
      Hi guys… I’ve entered the code exactly as instructed, into the config.js and when I refresh MM, it wont load…
      This is for the MMM-Smartthings module… and I put in the ‘Token’ between the commas as indicated.
      I admit im no expert here, but why so many brackets at the end?
      I even tried just using the normal open and close brackets, like my other modules, but still no joy.
      Any pointers please?
      Using the module
      To use this module, add the following configuration block to the modules array in the config/config.js file:
      var config = {
                    module: "MMM-Smartthings",
                    header: "Smartthings",
                      personalAccessToken: 'your_smarthings_api_key',
                      capabilities: [
                          'contactSensor',
                          'lock'
                      title: "Doors & Locks",
                      excludedDeviceNames: [
                          'Sense-', // Contains this text
                          'Virtual Lock Test' // Or is a specific device label
        sdetweil @johnnyboy
        @johnnyboy ok, that looks pretty!..
        one little check…
        when u added, did the module block BEFORE have a trailing , (more coming),
        if not YOU need to add it
        if where you added yours, there is stuff AFTER, does THIS module block have a trailing comma (more coming), if not YOU need to add one
        run the config checker
        npm run config:check
        when u see ‘unexpected token’, that means the line before is probably missing its comma, (more coming)
        johnnyboyJ 1 Reply Last reply
        • johnnyboyJ
          johnnyboy @sdetweil
          This is how it looks on screen
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			     // false, default for all  NON-armv6l devices
          module: 'alert',
          module: 'clock',
          position: 'top_center'
                        module: 'MMM-Smartthings',
                        position: 'top_left',
                        header: 'Smartthings',
                          personalAccessToken: '*****-*****-*****-*****',
                          capabilities: [
                              'contactSensor',
                              'lock'
          module: 'calendar',
          ^^^^ Above I tried with single quotes, having already tried double quotes as was indicated to
            sdetweil @johnnyboy
            @johnnyboy said in Config code not working?:
            well, ya got a few extra things in there
            every { needs a } and every [ needs a ]
            extras not allowed
            • johnnyboyJ
              johnnyboy @sdetweil
              That did it… I just knew there were too many brackets, but who am I to contradict the developer of that module?
              Thanks so much for pointing me in the right direction.
                              personalAccessToken: 'MY TOKEN GOES IN HERE',
                              capabilities: [
                                  'contactSensor',
                                  'lock'
              module: 'calendar',
              How the instructions said to do it!
                     'contactSensor',
                                  'lock'
              module: 'calendar',
                sdetweil @johnnyboy
                well, you have to read what he said, you copied too much… LOOK like this (his is correct), not BE EXACTLY this (as he only had one module)
                read the modules for beginners
                https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1592186111969
                • johnnyboyJ
                  johnnyboy @sdetweil
                  For sure I was’nt knocking him… I just followed what it said - to enter that block into Config…
                  I’m very much a novice in this, so I just enter what I see, or be told to by members, who know far more than I… but I did say at opening post that I was unsure if there should be so many brackets at the end…
                  But yeah, it works brilliantly… although I have quite a lot of Smartthings items… so the list goes all down the entire side of the screen, covering Compliments - Lower 3rd, and news feed - bottom bar. … so will need to make another post to find out how to reduce the font size using CSS.
                  Thanks again Sam… you have helped restore my interest in MM again, with your help on several of my posts.
                    sdetweil @johnnyboy
                    @johnnyboy https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1592231548825
