    Config code not working?
    8 Posts 2 Posters 1.2k Views 1 Watching
      sdetweil @johnnyboy
      @johnnyboy ok, that looks pretty!..
      one little check…
      To use this module, add the following configuration block to the modules array in the config/config.js file:
      when u added, did the module block BEFORE have a trailing , (more coming),
      if not YOU need to add it
      if where you added yours, there is stuff AFTER, does THIS module block have a trailing comma (more coming), if not YOU need to add one
      run the config checker
      npm run config:check
      when u see ‘unexpected token’, that means the line before is probably missing its comma, (more coming)
      johnnyboyJ 1 Reply Last reply Reply Quote 1
      • johnnyboyJ Offline
        johnnyboy @sdetweil
        This is how it looks on screen
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			     // false, default for all  NON-armv6l devices
        module: 'alert',
        module: 'clock',
        position: 'top_center'
                      module: 'MMM-Smartthings',
                      position: 'top_left',
                      header: 'Smartthings',
                        personalAccessToken: '*****-*****-*****-*****',
                        capabilities: [
                            'contactSensor',
                            'lock'
                        title: "Doors & Locks",
                        excludedDeviceNames: [
                            'Sense-', // Contains this text
                            'Virtual Lock Test' // Or is a specific device label
        module: 'calendar',
        ^^^^ Above I tried with single quotes, having already tried double quotes as was indicated to
        module: "MMM-Smartthings",
                      header: "Smartthings",
          sdetweil @johnnyboy
          @johnnyboy said in Config code not working?:
          well, ya got a few extra things in there
          every { needs a } and every [ needs a ]
          extras not allowed
          johnnyboyJ 1 Reply Last reply Reply Quote 0
            johnnyboy @sdetweil
            That did it… I just knew there were too many brackets, but who am I to contradict the developer of that module?
            Thanks so much for pointing me in the right direction.
                            personalAccessToken: 'MY TOKEN GOES IN HERE',
                            capabilities: [
                                'contactSensor',
                                'lock'
            module: 'calendar',
            How the instructions said to do it!
                   'contactSensor',
                                'lock'
            module: 'calendar',
              sdetweil @johnnyboy
              well, you have to read what he said, you copied too much… LOOK like this (his is correct), not BE EXACTLY this (as he only had one module)
              read the modules for beginners
              https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1592186111969
                johnnyboy @sdetweil
                For sure I was’nt knocking him… I just followed what it said - to enter that block into Config…
                I’m very much a novice in this, so I just enter what I see, or be told to by members, who know far more than I… but I did say at opening post that I was unsure if there should be so many brackets at the end…
                But yeah, it works brilliantly… although I have quite a lot of Smartthings items… so the list goes all down the entire side of the screen, covering Compliments - Lower 3rd, and news feed - bottom bar. … so will need to make another post to find out how to reduce the font size using CSS.
                Thanks again Sam… you have helped restore my interest in MM again, with your help on several of my posts.
                  sdetweil @johnnyboy
                  @johnnyboy https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1592231548825
