    London tube status
    13 Posts 4 Posters 8.7k Views 6 Watching
    • yawnsY Offline
      yawns Moderator
      Absolutely. I signed up for a developer account but did not find the time on the weekend to go for it. The API indeed looks neat.
        djbenny07 @nigel-daniels
        @nigel-daniels @yawns OK great cant wait to see what you come up with
        • N Offline
          nigel-daniels @djbenny07
          @djbenny07 I just posted the first version of a module to do this MMM-Tube-Status under the Transport section here. Let me know how you get on with it. If you find any bugs just let me know and I’ll try and figure it out.
          I will be making an update at some point; as far as I can tell I ‘should’ be using an app_id and an api_key but whenever I try to use them I cannot get data at all. I’ve emailed TfL to try and figure out what’s going on. In the meantime I’ve used the anonymous version of their API and it seems to work, I’m just not sure if it will run out of requests at some point. I.e. it may just stop at some point.
          As soon as I know more I’ll update the module’s topic and let you know.
            soqueen
            Love this! signed up for a dev account myself and was trying to figure out how to write this. My only question when I load this as a module - the module takes up the entire width of my screen. Is there a way to set a size on it?
            • N Offline
              nigel-daniels @soqueen
              @soqueen hi what does your config look like? If you PM it to me (sans API keys etc.) I’ll try and recreate the issue and suggest a correct config or add a fix to the css.
                soqueen @nigel-daniels
                @nigel-daniels Thanks for getting back to me! Do you want the entire config or just the tube station portion of it? I will PM it to you shortly…
                • N Offline
                  @soqueen probably best to send me he whole thing just in case it’s an interaction thing, just remove any private api keys and any personal urls (e.g. calendar).
                    @soqueen
                    I apologize, I can’t seem to figure out how to PM you. If it’s ok, I can just paste the config file (sans personal info) here.
                      soqueen
                      /* Magic Mirror Config Sample
                      • MIT Licensed.
                      var config = {
                      port: 8080,
                      language: 'en',
                      timeFormat: 24,
                      units: 'imperial',
                      		module: 'alert',
                      		module: 'MMM-Tube-Status',
                      		position: 'bottom_bar',
                      		header: 'Tube Status',
                      			show_all:  true
                      		module: 'MMM-Remote-Control'
                      // module: ‘MMM-Modulecheduler’,
                      // config: {
                      // notification_schedule: [
                      // //turn the moniter on at 6:30 am daily
                      // {notification: ‘REMOTE_ACTION’, schedule: '30 6 * * * ', payload: {action: “MONITORON”}},
                      // //turn off the monitor at 22:30 daily
                      // {notification: ‘REMOTE_ACTION’ schedule: ‘30 22 * * *’, payload: [action: “MONITOROFF”}},
                      // //restart magicmirror 2am sundays
                      // {notification: ‘REMOTE_ACTION’, schedule: ‘0 2 * * SUN’, payload: [action: “RESTART”}}
                      		module: 'clock',
                      		position: 'top_left'
                      		module: 'MMM-Wunderlist',
                      		position: 'top_left',
                      		header:  'To-Do',
                      			accessToken: '',
                      			clientID: '',
                      			lists: ["Work", "Family"]
                      		module: 'calendar',
                      		header: 'Jennifer Calendar',
                      		position: 'middle_center',
                      					symbol: 'calendar-check-o',
                      					url: ''
                      					url: '',
                      					url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                      		module: 'calendar',
                      		header: 'Sarika Calendar',
                      					symbol: 'diamond',
                      					url: ''
                      		module: 'compliments',
                      		position: 'top_bar'
                      		module: 'currentweather',
                      		position: 'top_right',
                      			locationID: '',  //ID from http://www.openweathermap.org
                      			appid: ''
                      		module: 'weatherforecast',
                      		header: 'Weather Forecast',
                                  appid: ''
                      		module: 'newsfeed',
                      			feeds: [
                      					title: "BBC Top Stories",
                      					url: "http://feeds.bbci.co.uk/news/rss.xml"
                      			showSourceTitle: true,
                      			showPublishDate: true
                      if (typeof module !== ‘undefined’) {module.exports = config;}
                      • N Offline
                        @soqueen sorry I thought the site supported PMs, my bad. Looking at the config you have you have the tube status set to show across the bottom of the screen:
                        If you move it to show in something like 'bottom_center' then it will restrict the width of the module. Check out the MM2 Read Me for the valid location settings. Hopefully this will correct the issue you are seeing, let me know if it remains a problem.
