    MMM-Tube-Status (London Underground)
    25 Posts 5 Posters 22.3k Views 6 Watching
    • N Offline
      nigel-daniels
      This module will display the status of the the lines on the London Underground based on the API provided by Transport for London (TfL) here. This module lets you see all of the lines or just those impacted by a part or full closure. You can get this module from here. Enjoy!
      • yawnsY Offline
        yawns Moderator
        Looks nice, just about what I had in mind with colours.
          djbenny07
          thanks very much. not installed a new module before so we’ll see how it goes!
          Is there any instructions on module installation? to put in the config.js as to the location of the module on the screen?
          • N Offline
            nigel-daniels @djbenny07
            @djbenny07 check out the read me file on Github, it details the options and provides an example.
            • N Offline
              nigel-daniels @yawns
              @yawns I was thinking of making the font the line colours but then the Northern line would have never shown up :( It turns out TfL provide detailed UI and colour guides so I was able to get the correct colours for each line.
                djbenny07 @nigel-daniels
                @nigel-daniels I have done as the config suggests however the display says it needs a valid config file.
                yawnsY 1 Reply Last reply Reply Quote 0
                • yawnsY Offline
                  yawns Moderator @djbenny07
                  @djbenny07
                  Then please show your entire config file. If the config.js file is there but the mirror says it is missing then there is something missing, most of the time , or }
                  Please put ` (back ticks) before and after your config file content when posting, then it will be parsed and shown correctly. Also please remove appids/app tokens, they should be kept private.
                    djbenny07
                    var config = {
                    port: 8080,
                        language: 'en',
                        timeFormat: 24,
                        units: 'metric',
                                        module: 'alert',
                                        module: 'clock',
                                        position: 'top_left'
                                        module: 'calendar',
                                        header: 'Public Holidays',
                                        position: 'top_left',
        symbol: 'calendar-check-o ',
        url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                                        module: 'compliments',
                                        position: 'lower_third'
                                        module: 'currentweather',
                                        position: 'top_right',
                                                locationID: '245613',  //ID from http://www.openweathermap.org
                                                appid: 'ID Number taken out'
                                        module: 'weatherforecast',
                                        header: 'Weather Forecast',
                      djbenny07 @djbenny07
                      @djbenny07 i took it out of there as it didnt work. could it be corrected? is it possible to get it on the right hand upper corner underneath the clock?
                      • bheplerB Offline
                        bhepler Module Developer @djbenny07
                        @djbenny07 Is that the entire config file? I ask because it’s not closed properly.
                        Please put the module configuration that you’re trying to get to work back in and post the entire file for us so we can check it all. We’ll get you running.
                        • 1 / 3
