    MMM-Tube-Status (London Underground)
    25 Posts 5 Posters 24.0k Views 6 Watching
      djbenny07
      var config = {
      port: 8080,
          language: 'en',
          timeFormat: 24,
          units: 'metric',
                          module: 'alert',
                          module: 'clock',
                          position: 'top_left'
                          module: 'calendar',
                          header: 'Public Holidays',
                          position: 'top_left',
                                                  symbol: 'calendar-check-o ',
                                                  url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                          module: 'compliments',
                          position: 'lower_third'
                          module: 'currentweather',
                          position: 'top_right',
                                  locationID: '245613',  //ID from http://www.openweathermap.org
                                  appid: 'ID Number taken out'
                          module: 'weatherforecast',
                          header: 'Weather Forecast',
        djbenny07 @djbenny07
        @djbenny07 i took it out of there as it didnt work. could it be corrected? is it possible to get it on the right hand upper corner underneath the clock?
          bhepler Module Developer @djbenny07
          @djbenny07 Is that the entire config file? I ask because it’s not closed properly.
          Please put the module configuration that you’re trying to get to work back in and post the entire file for us so we can check it all. We’ll get you running.
            djbenny07
            • N Offline
              nigel-daniels @djbenny07
              @djbenny07 I noticed that at the end of the file the last two lines should change and it should end something like:
              If you then want to add the tube status module something like this should work:
              module: 'MMM-Tube-Status',
              header: 'Tube Status'
              I hope that helps.
              • N Offline
                nigel-daniels
                BTW I have just updated the code so that if the optional show_all=false config is used and all of the lines are offering a good service there is a line displayed to indicate this rather than the module just disappearing.
                  djbenny07
                  OK I have found that i didn’t copy all the text. the below does not work
                  var config = {
                  port: 8080,
                      language: 'en',
                      timeFormat: 24,
                      units: 'metric',
                                      module: 'alert',
                                      module: 'clock',
                                      module: 'calendar',
                                              locationID: '264443',  //ID from http://www.openweathermap.org
                                              appid: 'number'
                                  appid: 'Number'
                              header: 'Tube'
                                      module: 'newsfeed',
                                      position: 'bottom_bar',
                                              feeds: [
                                                              title: "BBC Top Stories",
                                                              url: "http://feeds.bbci.co.uk/news/rss.xml"
                                              showSourceTitle: true,
                                              showPublishDate: true
                  if (typeof module !== ‘undefined’) {module.exports = config;}
                  strawberry 3.141S N 2 Replies Last reply Reply Quote 0
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @djbenny07
                    @djbenny07 you missed 3 commas in there
                        header: 'Tube'
                    • N Offline
                      @djbenny07 ok there were a couple issues here that my linter picked up:
                      1. the tube module must look like this:
                      header: 'Tube'
                      Note the terminating commas on each line bar the last one in the braces.
                      1. The final line seems to use ticks to quote undefined not single quotes so it should be:
                      It can happen that copying between editors, email clients, browsers, etc introduces this sort of error and it’s a real pain to spot!
                      I hope this fixes it up for you.
                        djbenny07
                        can the position be the same as another module though? i still get the message to saying ‘Please create config file’
                        as my clock is in top_left
                        EDIT: Just noticed that i missed the ’ from the module name. added that in and still issue
                        • Y Offline
                          yawns Moderator @djbenny07
                          @djbenny07 you are still missing the closing , at the end of the tube module lines, as several users mentioned above
                            djbenny07 @yawns
                            @yawns yes my bad. i noticed this and corrected it. still same message
                            • Y Offline
                              @djbenny07 are you kidding? Look at the three lines you got there for the tube module. All three lines MUST end with a comma
                                djbenny07 @yawns
                                @yawns haha, im being really dumb i know. i have finally seen it, long day. thats what im going to blame it on.
                                its working now!
                                N 1 Reply Last reply Reply Quote 1
                                • Y Offline
                                  yawns Moderator
                                  Sometimes a knock at the back of ones head is worth a try.
                                  Good to see it’s finally working :-)
                                  • N Offline
                                    @djbenny07 Yeay! It lives :)
                                      djbenny07
                                      i presume to update the module i just run this again?
                                      git clone https://github.com/nigel-daniels/MMM-Tube-Status.
                                      • Y Offline
                                        @djbenny07
                                        enter the MMM-Tube-Status folder and run git pull, that should pull all changes from github
                                        If you run the clone command again it will tell you the target directory already exists
