    MMM-Tube-Status (London Underground)
    25 Posts 5 Posters 23.3k Views 6 Watching
      djbenny07
      • N Offline
        nigel-daniels @djbenny07
        @djbenny07 I noticed that at the end of the file the last two lines should change and it should end something like:
        module: 'weatherforecast',
        position: 'top_right',
        header: 'Weather Forecast',
        locationID: '245613', //ID from http://www.openweathermap.org
        appid: 'ID Number taken out'
        If you then want to add the tube status module something like this should work:
        module: 'MMM-Tube-Status',
        position: 'top_left',
        header: 'Tube Status'
        I hope that helps.
        • N Offline
          nigel-daniels
          BTW I have just updated the code so that if the optional show_all=false config is used and all of the lines are offering a good service there is a line displayed to indicate this rather than the module just disappearing.
            djbenny07
            OK I have found that i didn’t copy all the text. the below does not work
            var config = {
            port: 8080,
                language: 'en',
                timeFormat: 24,
                units: 'metric',
                                module: 'alert',
                                module: 'clock',
                                module: 'calendar',
                                header: 'Public Holidays',
                                                        symbol: 'calendar-check-o ',
                                                        url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                                module: 'compliments',
                                position: 'lower_third'
                                module: 'currentweather',
                                        locationID: '264443',  //ID from http://www.openweathermap.org
                                        appid: 'number'
                            appid: 'Number'
                        header: 'Tube'
                                module: 'newsfeed',
                                position: 'bottom_bar',
                                        feeds: [
                                                        title: "BBC Top Stories",
                                                        url: "http://feeds.bbci.co.uk/news/rss.xml"
                                        showSourceTitle: true,
                                        showPublishDate: true
            if (typeof module !== ‘undefined’) {module.exports = config;}
            strawberry 3.141S N 2 Replies Last reply Reply Quote 0
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @djbenny07
              @djbenny07 you missed 3 commas in there
                  header: 'Tube'
              • N Offline
                @djbenny07 ok there were a couple issues here that my linter picked up:
                1. the tube module must look like this:
                header: 'Tube'
                Note the terminating commas on each line bar the last one in the braces.
                1. The final line seems to use ticks to quote undefined not single quotes so it should be:
                It can happen that copying between editors, email clients, browsers, etc introduces this sort of error and it’s a real pain to spot!
                I hope this fixes it up for you.
                  djbenny07
                  can the position be the same as another module though? i still get the message to saying ‘Please create config file’
                  as my clock is in top_left
                  EDIT: Just noticed that i missed the ’ from the module name. added that in and still issue
                  • yawnsY Offline
                    yawns Moderator @djbenny07
                    @djbenny07 you are still missing the closing , at the end of the tube module lines, as several users mentioned above
                      djbenny07 @yawns
                      @yawns yes my bad. i noticed this and corrected it. still same message
                      • yawnsY Offline
                        @djbenny07 are you kidding? Look at the three lines you got there for the tube module. All three lines MUST end with a comma
                          djbenny07 @yawns
                          @yawns haha, im being really dumb i know. i have finally seen it, long day. thats what im going to blame it on.
                          its working now!
                          N 1 Reply Last reply Reply Quote 1
                          • yawnsY Offline
                            yawns Moderator
                            Sometimes a knock at the back of ones head is worth a try.
                            Good to see it’s finally working :-)
                            • N Offline
                              @djbenny07 Yeay! It lives :)
                                djbenny07
                                i presume to update the module i just run this again?
                                git clone https://github.com/nigel-daniels/MMM-Tube-Status.
                                • yawnsY Offline
                                  @djbenny07
                                  enter the MMM-Tube-Status folder and run git pull, that should pull all changes from github
                                  If you run the clone command again it will tell you the target directory already exists
